02-02-2013, 09:57 PM | #1 |
Random Misc Parts
Trying to do some cleaning up and put a little cash back in my pocket to buy more parts. I have no clue what some of these parts are worth. Shipping will be from 72116 area. Or, I may have a friend going to Springfield MO in the next week, or I may be going to Kansas city in a month??
1. GMC horn button n hardware, faded bad. 5+shipping? 2. Some tube that goes in the left rear of a blazer/jimmy. 5+shipping 3. Dana20 transfer case that is taken apart because the trans output shaft broke off in it I think I was told? I didnt take it apart, not sure everything is there, or its condition. Will not ship. No clue on price. 4. Blazer gas tank straps, and that ubolt that goes on the right side, 20 gallon. 10+shipping? 5. Chevy tail gate strip. Driver quality. Faded, few dings. Would need to find box to ship it in. I saw a nicer one of these go for 75 on here. How about 50+shipping? 6. Brand new GM cross member part number 14034558 No clue on price. 7. Air cleaner spacer from a 72 chevy 350. 5+shipping 8. MSD cap, rotor button, points, condenser, wires. Cap is chipped at one of the mounting points, but holds solid. Has been mounted, but never ran on. 10+shipping for all of it. 9. Fuel sending unit/pump for a 91 burb 40gal tank. 20+shipping 10. 4 gmc headlight buckets, no rings. Fairly rough 5+shipping 11. Powerflow 10652 regulator. Used for a few test starts. 50+shipping 12. 2 lock rings and orings for tbi fuel tanks. 5+shipping each 13. Blazer/jimmy door window to double wall top seals. From LMC, never used. 35+shipping 14. Not pictured, I have some motor brackets for 69-72, 2wd, v8. They are dirty, need cleaned, but solid. 15+shipping.
2008 Sierra k3500 LMM 1994 s10 blazer 4x4 1991 Camaro Vert Rusted in Half RIP 1972 Jimmy 4x4 L05,4L60E,np205http://67-72chevytrucks.com/vboard/s...d.php?t=546364 1967 C10 L6/3tree(dads truck) |
02-03-2013, 07:20 AM | #2 |
It's alsways something.....
Re: Random Misc Parts
#13 -Part number for Blazer door window top seals from LMC truck please
Are these the same for single wall tops? Does this do both doors? Inline pending info
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
02-03-2013, 09:53 AM | #3 |
Active Member
Will take #4 straps, if no damage or rust thru. thanks
02-03-2013, 11:07 AM | #4 |
chuckmc8. double wall, both doors. 38-6950
6t727t2. There is some surface rust, and the one is bent a little, but would straiten out once installed. Would you still like? |
02-04-2013, 06:56 AM | #5 |
Looks like double wall- I need single wall stuff, Thanks anyway
02-04-2013, 07:37 AM | #6 |
Active Member
What will total be with shipping for the straps to zip 08015?
02-04-2013, 08:43 AM | #7 |
02-05-2013, 02:57 PM | #8 |
Can you post a pic of the fuel tank ubolt? Any damage to the threads?
02-05-2013, 08:29 PM | #9 |
Seventyone, Let me check and see if 6t still wants them. But I do recall unthreading everything to get it out.
02-06-2013, 09:09 AM | #10 |
Seventyone, 6t passed on the straps. Will get a picture of the ubolt later tonight once I get home from work.
02-06-2013, 09:04 PM | #11 |
seventyone. Here are your pics. One side the rod does appear slightly bent up high. But no cross threading. I would still run a die nut just to clean them up.
02-08-2013, 12:55 PM | #12 |
I think I'll pass thanks though.
02-09-2013, 12:18 AM | #13 |
whats the price of the tailgate band shipped to 71055? I would like to see some better pics.
02-09-2013, 12:20 AM | #14 |
02-09-2013, 09:52 AM | #15 | |
post office, 17.39 So 67 dollars, with hoping I can find a box. Will get pictures later today when the sun is out. |
02-09-2013, 11:11 AM | #16 |
Sounds good..do you know if the band is OEM? are the letters metal or plastic?
02-09-2013, 03:09 PM | #17 |
Should be all original, letters are metal. Here are more pics.
02-10-2013, 03:06 AM | #18 |
let me think on it.. thanks
