Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 02-12-2013, 12:30 PM   #1
newbe351
Book shelf speakers?
I read here or on another forum where someone cut down a pair of bookshelf speakers (Sony I believe) and stuck them under the seat. Is this a viable option? Being electronically challenged, can you run home speakers with a car radio? I'm probably looking at the Retrosound radio for my '66, but am having some trouble coming up with speaker ideas. I hear bad things about the kick panel speakers and besides just completed the interior including the kick panels and don't want undo what I just did. Would something like the Bose Acoustimass (or whatever they're called) cube speakers work under the seats?
newbe351 is offline   Reply With Quote
Old 02-12-2013, 12:33 PM   #2
Billett
Billett's Avatar
Re: Book shelf speakers?
you can replace the stock dash 4x10 with a pair of 4" speakers. I also fit a pair of 6.5" speakers under the seat in my '68 but some 5.5" ones would fit easier. What's the price range you are looking for? Maybe we can help you out with a set up?
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 02-12-2013, 12:52 PM   #3
jimmydean
jimmydean's Avatar
There is a little room to do something like the cab corner setups for a 6.5 or 6x9 with minimal effort. I don't have a fuel tank in my cab, so I am putting my 6.5's as high as they go in the cab corner, but low down works well, too. Most bookshelf/home audio is 8ohm, so be aware of your impedance and I am not a fan of Bose components, there are better speakers to be had for cheaper that are designed for an enclosed cab.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-13-2013, 01:06 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
i found some small tv surround speakers that where the right ohms
considered changing the speakers inside but they worked/sounded ok
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
