Old 02-14-2013, 09:55 PM   #1
BabyBlue
The Peacemaker
BabyBlue's Avatar
1999-2002 Shortbed 2wd's
Looking for ideas for a new truck I just bought. It's a 2002 C1500 standard cab SWB, 5.3L, all the bells and whistles, completely stock with exception of some later model 20" Factory Alloys and a bed liner. Oh, it also has 66k miles on it. Bought it to replace my 2011 which I am getting rid of along with my Yukon. I was looking for the following idea's.
-Headers
-Cam/Valvetrain
-Heads
-Headlights
-Tonneau cover
Later on
-Suspension mods (probably a static drop....or I have a E3 Air management kit that I could use).
1978 Chevy 2wd Stepside
aka "Audrey"
Cordova brown with mandarin guts
79k original miles & being restored
1979 Chevy 2wd Short Wide
aka "Emma-Jayne"
2019 Chevy Tahoe LT
Previous rides:
-2002 Firehawk T/A, 2006 Trailblazer SS AWD, 2014 GMC Sierra RCSB, 1971 2wd Blazer, 1996 SNB, 1997 2dr 2wd Yukon, 2001 Silverado RCSB, 2011 Silverado Z71 4x4, 1982 2wd Blazer, 1997 2dr Tahoe, 1970 Chevelle SS, 1972 2wd Blazer, 1986 Silverado Stepside, 1995 S-10, 1985 Silverado SWB.
BabyBlue is offline   Reply With Quote
Old 02-14-2013, 10:19 PM   #2
treman03
treman03's Avatar
Re: 1999-2002 Shortbed 2wd's
These are going to be delivered to my door tomorrow. Made an offer of $300 and got it.
http://www.ebay.com/itm/GMC-CHEVY-SU...93efe9&vxp=mtr
1999 Chevrolet Silverado
treman03 is offline   Reply With Quote
Old 02-15-2013, 04:21 PM   #3
biggsteve97
this is a nice kit. I have it on my 03 Tahoe and love the fit and sound. It is a little tight on the driver side drive-shaft if you have 4wd. mine barely cleared have considered dimpling to improve clearance because in really bumpy conditions i hear the header tap the drive-shaft lightly. Would definitely recommend reusing the factory exhaust manifold steel gaskets, the paper ones in the kit will leak. The factory why pipe is a pain to get out! Better have a sawzall handy you will need it. There is a whole blog on this header kit on here its called eBay Long Tube header install. Has lots of pics and videos. The number 3 cylinder plug wire may not be long enough to clear the weird hump up in the header. I used MSD plug wires with adjustable boots to clear and they also handle the heat from the header much better. I also used a billet egr blockoff to block the egr pipe on the passenger side. it just bolted right on.
biggsteve97 is offline   Reply With Quote
Old 02-16-2013, 12:47 AM   #4
Sooner84
Sooner84's Avatar
^^ good info. Although I'm not running those headers ive heard good things about them. For the egr block off I used a rubber freeze plug that you can buy from orielys for a couple bucks. I'm running a smaller cam that works good with the stock stall, it's a comp 212/218 low lift 114 lsa and love it. While you're doing the cam swap I would definitely buy better valve springs and pushrods. A good and cheap mod would also be to install a corvette servo in your transmision, I bought mine from Oregon performance for $13. As far as heads go I would try and find a used set of 243/799 heads in good condition and mill them .030" to get compression back up. And for your headlights you could buy hid kits from ddm tuning which is what I did.
1984 chevy swb(1st truck, sold..)
2001 RCSB silverado, 5.3 with a little extra
2004 ECSB Silverado LT, 5.3 cam & bolt ons, 4l60e shift kit/stall, g80 & 3.73s
My first (1984 c10) Build
Sooner84 is offline   Reply With Quote
