Old 02-17-2013, 06:19 PM   #1
Kidd-7
Kidd-7's Avatar
Question Blown Head gasket with clean oil????
I have an 01 Impala with the 3400 engine; 74K miles. I had a heat problem about a month ago. The temp gauge would rise to about mid way very fast and the heat would blow cool, then the gauge would drop back down to normal and heat would be nice n warm.
I eventually did a flush n fill on the coolant, it was nasty brown, it took 5 gallons to clean out the overflow. This seemed to correct the problem, temp gauge has been stable, heat is hot.
Well yesterday I noticed the gauge being erratic, not to the extreme it was, but still moving more than normal. So when I got home I opened up the overflow and its bubbling, not boiling, bubbling like air is coming out of the system.
Any ideas, my friend who is a mechanic said the head gasket in these engines are common to fail, but when I flushed n filled I also changed the oil, its still clean.
Is it a head gasket letting combustion gasses in the cooland but not letting coolant in the oil?
It it possible I did not purge all the air out?
-thanks.
71 C-10 - 307 - 3 on tree
01 Ford Explorer 5.0 v8
96 Mercury Cougar v8
79 Trans Am 403 Olds
Kidd-7 is offline   Reply With Quote
Old 02-17-2013, 08:42 PM   #2
bighaas79
Re: Blown Head gasket with clean oil????
Very possible with these engines.
bighaas79 is offline   Reply With Quote
Old 02-18-2013, 12:38 AM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
Dexcool is to be changed every 100K or 5 years, whichever comes FIRST. However, with it looking that bad... it almost looks like someone added the green stuff to it, which is bad, because it causes it to gel. They make a special green now, called Global, or something, and it can be mixed with dexcool, but nothing else. And yes, it could be going out the exhaust. Is it actually losing coolant?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-18-2013, 10:12 AM   #4
Kidd-7
Kidd-7's Avatar
I'm not loosing coolant, I did a flush n fill at about 100K and used the mix with any Coolant then. So I'm pretty sure that the coolant didn't get mixed to create this crap, but seeing it makes me think I might have made a mistake at some point.
When I got to work this morning I took a look at the overflow and it was white and foamy, I'm going to check the coolant when I have a chance, to see what color it is now.
Old 02-24-2013, 12:34 AM   #5
68C15
blood type; Retumbo
68C15's Avatar
do you have a missfire or running rough when started in the morning? these family of engines like to blow the gasket by cylinder #1 (back of engine under alternator)
my bet is on a blown gasket. be carefull, these blocks also like to rust away on the corner and then you're screwed
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 02-25-2013, 01:12 PM   #6
Kidd-7
Kidd-7's Avatar
It coughs sometimes in the morning, have to crank it a little long to start up. It has done this for a while though and I've never had heating issues. I was told that the mix with any anitfreeze isn't good either. So I may flush it again and use the orange stuff this time. Also, can you see the rust from the outside, or is it an internal thing? Shop quoted me at least $2K for the head gasket. If I do it she'll be down for weeks b/c of time. Maybe a rebuilt 3800????
Old 02-26-2013, 08:22 PM   #7
spudz
spudz's Avatar
These a are REALLY bad about blowing intake gaskets and mixing water and oil, But also i have seen alot of blow head gaskets on these too. If they get anywhere close to hot, even once the gaskets pop. Its a VERY easy car to work on. You can have the heads off in a hour. But yes, its POSSIBLE that it can have a blown headgasket and not run hot or mix water and oil,
2004 z71, 96 z71 on 38s, 88 Chevy k5 blazer, 4in lift. 84 swb project, 82 SWB project , 84 chevy 4x4 lwb project, 88 Jimmy beater/highschool ride. 79 c30. 99 tahoe 4x4 project. and a bunch of parts trucks..
spudz is offline   Reply With Quote
Old 03-18-2013, 04:55 PM   #8
Kidd-7
Kidd-7's Avatar
well I think I might have fixed it. The small hose from the water pump to the metal tube accross the front of the engine blew; steam & ran real hot on the way to work.
I replaced that hose and bled the air out. I haven't had the issue since.
Fingers crossed...
