Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 02-18-2013, 12:59 PM   #1
jimmydean
jimmydean's Avatar
Amber gets tunes.
So the insurance cut me a check for my car finally and I went shopping. I picked up a very nice '92 Silverado 2500 with low miles and had not been abused or cut up (that's my job).
My daughter calls her Amber because of the red stripe. I like it.
The dealer I got the truck from had just replaced the heater core, so that was a bonus. The interior is crazy clean, but I noticed a lot of rust on the base of the seat and the bolts on the drivers side were rusted. After a lot of PB blaster, I got the seat out.
Tore the interior out
When I pulled the carpet up, the drivers side was soaked. The pad was dripping and the floor looked awful. So out goes the carpet and pad.
Wire wheel
Rust encapsulator and top coat
Back to the stereo. The stock '92 has 4x6 in the dash and 4x6 in the rear pilar. I didn't want to do a bunch of work, so I decided to replace the dash with 4" round 2 ways and the rear with 4x6 2 ways.
Here's what I got all together:
Pair of 4" round (dash)
Pair of 4x6 (rear)
Pair of 6.5" separatres (door)
10" shallow sub (rear)
MTX TN400/4 400 watt 4 channel.
Out with the old, in with the new
Sub box (.75 cubic ft sealed) and amp rack. Sub isn't centered because I wanted to fit the tool box back in on the passenger side.
Doors before:
Doors now (tape was holding speaker for mock up )
Got a little dark (it was very late )
Sounds pretty damn good. Total cost was just under $300 total (deck was in the truck).
Amp: $60 pawn shop
Mid/High Speakers: $100 Frys Electronics
Sub: $80 Car stereo store
Speaker Wire: $25 50ft at Radio Shack
Wood, misc crap: $35 Home Depot
I have some intermiten motor noise, so I went to Car Toys to see if they had any ideas. I thought it might be my ground. The shop manager took a look at it and said "This looks better than half the guys in here" I fewlt better about that.
I think it's in the deck. But it works for now. Enjoy.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 02-18-2013, 04:13 PM   #2
jimmydean
jimmydean's Avatar
Re: Amber gets tunes.
I did need to trim the vents in the dash to clear the slightly deeper round speakers. I used a dremel to trim a section out and used foil tape to seal it back up so the vent is still functional. I also want to trim some dash out to get the deck to sit more flush. Will have to wait on that for now.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-19-2013, 09:23 PM   #3
jimmydean
jimmydean's Avatar
39 views and not one comment? I didn't think it was that ghetto
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-20-2013, 10:55 PM   #4
Gonepostal
Gonepostal's Avatar
Looks like you did a good job, any idea why the carpet was so wet?
Gonepostal is offline   Reply With Quote
Old 02-21-2013, 01:23 PM   #5
jimmydean
jimmydean's Avatar
The heater core leaked inside the cab. The dealership had just replaced it, but based on the amount of rust, it must have been leaking for years. There was quite a bit of antifreeze in both the carpet pad and the heat insulation on both driver and passenger sides. The drivers side was the worst.
There was a puddle of water under the sill plate where the speaker wires and dome light wires run on the drivers side. I still can't get the drivers seat belt bolt out, it's rusted solid.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 02-23-2013, 06:17 AM   #6
derrickmanx1
derrickmanx1's Avatar
Looks good. I'll bet it sounds better than the stocker lol.
NAME: TRAVIS TRUCK: BRUISER
71 C/10 SWB 3.5/5" drop 4.11 GEARS.
F.A.S.T. BBC 408 496hp/479ft/lb
JAKES 4L80E TCI TCU PTC 10.5" 2800 STALL
My build thread: http://67-72chevytrucks.com/vboard/s...30#post5779530
derrickmanx1 is offline   Reply With Quote
Old 02-25-2013, 01:19 PM   #7
jimmydean
jimmydean's Avatar
So I got everything built and went to put the tool box back in and realized I am an idiot.
The lid of the stock tool box is 26", but the tray of tools inside the tool box is 29". So I ended up having to move the sub and amp rack over 3", then reinstall/rewire everything. I did most of the work at my buddys house and ended up forgetting my modified tool box at his house. So I still need to put the tool box back in once I get it back.
The good news is the stock carpet the covers the back was now 3" too short, but the other side (that I am not using) was enough to cover it. I just had to trim it to fit, then redrill the mounting holes in the carpet.
I wish I had a real SPL meeter, phone mics cut out above 100db, so you can't get a true measure using an app. But it does show good sound spectrum curves, so I am happy considering I don't have a true active crossover, just the filters on the amp.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
