02-23-2013, 11:59 AM | #1 |
1999 silverado
6.0 i just power progamed the engine and when i mash the pedal to the floor it stumbles. myy question is what is causing the stumble. its almost like it isnt getting enough gas or air upon hard acceleration
02-26-2013, 06:30 PM | #2 |
Re: 1999 silverado
ttt
03-02-2013, 10:59 AM | #3 |
Re: 1999 silverado
Good question. Maybe next time put more info in the title besides year And model.
Posted via Mobile Device |
03-03-2013, 10:01 AM | #4 |
Re: 1999 silverado
yes i will try that next time, but your no. 96 and still havent got a reply to my question
03-04-2013, 12:01 PM | #5 |
Re: 1999 silverado
what he is saying is give people more info now, so they have a way to tell what youre talking about
70 C10 working on a LSx swap 4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol |
03-04-2013, 12:29 PM | #6 |
Re: 1999 silverado
what other info would be helpful?
03-04-2013, 12:33 PM | #7 |
Re: 1999 silverado
I dont know a huge amount of these trucks but usually year model engine trans 2x4? 4x4? EC? SC? what rear gear? what mods have been done? if any?
03-04-2013, 12:50 PM | #8 |
Re: 1999 silverado
the engine and year is there already
03-04-2013, 02:27 PM | #9 |
Re: 1999 silverado
The type of programmer you used would help and what settings you may have changed if possible would help.
2006 Silverado 2500 HD |
03-04-2013, 02:55 PM | #10 |
Re: 1999 silverado
I used the Hypertech, changed the rev limiter, shift points, octane
03-04-2013, 05:26 PM | #11 |
Re: 1999 silverado
What grade or octane of fuel are you running on right now? If your still running on the lower octane fuel your gunna see a stumble.
03-04-2013, 06:46 PM | #12 |
Re: 1999 silverado
91 or higher
03-04-2013, 08:40 PM | #13 |
Re: 1999 silverado
I'm guessing you may have a plugged up fuel filter. With the hotter tune at wot it's going to demand more fuel.
03-04-2013, 09:22 PM | #14 |
Re: 1999 silverado
nope not that, that gets replaced reguraly
03-04-2013, 10:05 PM | #15 |
laying low
Re: 1999 silverado
I would have checked the fuel pressure 1st thing.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
03-04-2013, 10:25 PM | #16 |
Re: 1999 silverado
has a brand new pump put in tank
03-04-2013, 11:28 PM | #17 |
Re: 1999 silverado
What brand of pump? Just because its new doesn't mean it's good. Still need to check pressure with a gauge.
03-04-2013, 11:36 PM | #18 |
Re: 1999 silverado
it was checked and its good
03-04-2013, 11:39 PM | #19 |
Re: 1999 silverado
the engine stumbles more at 60 when you hard accelerate
03-05-2013, 07:55 AM | #20 |
Re: 1999 silverado
03-05-2013, 08:59 AM | #21 |
Re: 1999 silverado
i dont know as i did not put pump in ,it did the same thing with the old pump, was told new pump was working fine. when it stumbles and you let off pedal its ok
03-14-2013, 01:05 PM | #22 |
Re: 1999 silverado
ttt
03-14-2013, 02:11 PM | #23 |
Re: 1999 silverado
the bestpump for these trucks is the ac delco pump the others just dont put out the same.
i'd recommend unprograming the computer and see if its still there. also when was the lasttime it had plugs and wires,dis cap and rotor, and the air filter replaced? if it started after you changed something change it back and see if it goes away. start with the basics
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
03-14-2013, 05:04 PM | #24 | |
Re: 1999 silverado
03-14-2013, 07:21 PM | #25 |
Re: 1999 silverado
