Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 02-23-2013, 09:45 PM   #1
BlazinC5
BlazinC5's Avatar
97 S10 No start.. Arrrg.
So, A few weeks ago. The wife drove our 97 s10 blazer with a 4.3L home and parks it. A few days later I decide to go start it and move it. Well, it cranked over but would not start at all. So I mess with a few things. Like see if it is getting fuel. The pump kicked on and line had pressure. Even put a squirt of fuel down the intake and still, No start. I moved over to the ignition. pulled a wire, put a plug in it and grounded it, No spark... Ahh time to check coil.. Dang,, coil checks out as good. So next I check for power to the coil... I turned the key to the on position and .25 volts.. to the coil,, yes .25v. I believe it should be 12v. So now I guess I have to trace some wires.. In all this progress I also discovered that my fuel guage now is pegged out past full and don't move, (key on or off) And the voltmeter is as low as it goes and don't move either. Plus the fuel pump will not kick on automaticly. I can get it to pump using the bypass wire on the drivers side firewall tied directly to the battery and the pump sounds real good. but no start still and no good power to coil. So something is very wrong in the wiring...
Do any of you have a wiring schematic that would show the coils power source? The Haynes manuals are vague and I realy want to strangle every person who wrote for Ehow.com's articles. They are so random and vague they obviously knew nothing of what they were writing. Any help would be great. Oh, I also checked all my fuses and they are good and no trouble codes were set on the computer either.
71 2wd Blazer
My build, Restarted
05 Buell firebolt
94 1500 Z71
No rice for me,,, I'm full
BlazinC5 is offline   Reply With Quote
Old 02-23-2013, 11:22 PM   #2
BarryB
BarryB's Avatar
Re: 97 S10 No start.. Arrrg.
I don't have a shematic but it puts me to thinking a ground issue. have you made sure your battery connections are all good and not corroded? I've seen some crazy stuff happen over corroded battery ends.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 02-25-2013, 10:57 PM   #3
BlazinC5
BlazinC5's Avatar
I don't believe I have a ground issue. Especialy off the batt. cable ends. It seems that everything else is working with the exeption of what I mentioned in the first post. I still have to get the Electronic control module checked out too. It seems that Napa don't have the correct dongle to use their equipment and it's about 80-150 bucks to buy a new one. Lil bit pricey for a maybe it will work.. So I am gunna check a few other auto parts stores too. and see if they can tell me if it's ngood or bad.
71 2wd Blazer
My build, Restarted
05 Buell firebolt
94 1500 Z71
Old 02-26-2013, 05:33 PM   #4
Zane M
If you are going to get your module tested, have it done at multiple places.
I have found that you can take a bad module to 5 different places and at least two will tell you it is good.
Zane M is offline   Reply With Quote
