Old 02-24-2013, 11:11 PM   #1
weaintscared
weaintscared's Avatar
454 T56 help
Ill try to keep this short,, 1976 454 motor 1994 T56 transmission,, now I'm being told that they won't bolt up and work together and then someone else said it work. I cut a box and drawed out the trans it looks like it will bolt up,,but the clutch hole is smaller than the crankshaft on the bbc what clutch will work?
Anyone have any part #s
What do I use to make this work?
weaintscared is offline   Reply With Quote
Old 02-25-2013, 03:54 PM   #2
weaintscared
Re: 454 T56 help
no one have any info on this
Old 02-25-2013, 05:52 PM   #3
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: 454 T56 help
Not really understanding what you are asking.
Tom Vogel is offline   Reply With Quote
Old 02-25-2013, 06:45 PM   #4
1990SSchevy65
1990SSchevy65's Avatar
Re: 454 T56 help
When I had my 454ss, I wanted to do a T56 swap. I was told that it will not bolt up, but there is a guy on the www.454ss.com forum that has done it. I cannot remember what all was involved though. I cannot find it at the moment, but here is this http://www.camaroz28.com/forums/driv...-454-a-462828/
I hope that helps.
2003 Chevrolet CCSB 4x4 1500HD Mine
2011 Toyota Corolla S Wife's new ride
2002 Pontiac Grand Am SE2 Wrecked/Totaled 2014
1990 Chevrolet 454SS GONE 02/26/11
1991 S10 SCSB GONE 12/24/08
1965 Chevrolet LB GONE 06/06/05
GM for life
1990SSchevy65 is offline   Reply With Quote
Old 02-25-2013, 07:58 PM   #5
SS Tim
SS Tim's Avatar
Re: 454 T56 help
Try D&D maybe they can sort out your combination. Based on the fun I've had with the T56 in my 99 SS Camaro I would not put a stock trans. behind a 454 in a truck. http://www.ddperformance.com/
SS Tim is offline   Reply With Quote
Old 02-25-2013, 09:07 PM   #6
weaintscared
Re: 454 T56 help
The T56 flywheel is a small bore & the 454 is the large bore hole where the flywheel bolts up I need to no what flywheel to use to use the other stock T56 stuff
Old 02-25-2013, 09:08 PM   #7
weaintscared
Re: 454 T56 help
SS Tim what's the deal on the stock T56 you don't think it will work
Old 02-25-2013, 09:40 PM   #8
Andriod8
Andriod8's Avatar
Re: 454 T56 help
Try a NV4500 or NV5600.
Andriod8 is offline   Reply With Quote
Old 02-25-2013, 09:41 PM   #9
weaintscared
Re: 454 T56 help
I have the T56 already
Old 02-25-2013, 10:06 PM   #10
Ole Greenie
Ole Greenie's Avatar
Re: 454 T56 help
Although, I have subscribed by posting, I have thought as well about this swap. I think it would be nice to have a well shifting many tranny bolted up to my LS6. You can get the whole kit at TREMEC I believe. I have seen quite a few TREMEC T56s bolted up to BBC like ours in show/go cars and trucks. It is a bit pricey but the best...well is...the best.
Another option is a newer 5 or 6 speed auto that can be manually or electronically shifted. I like my auto though it is a bit rudimentary at this point but I am looking forward to a new auto 6-speed I can adapt a paddle type shifter to during those times when the ricers or otherwise HP newbies want to tangle.
Yes, they are electronically modulated but there are throttle adapters for any 4150 style carb or FI unit (FAST, Edelbrock, etc).
Eventually, I'll be going to TPI at the same time when I install the 6L transmission. Okay, a bit long, but look into what TREMEC has to offer here:
http://www.hurst-drivelines.com/?page_id=155
Cheers and all the best. Be sure to update us on your choices! God Bless!
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
New motor install Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=667773
Ole Greenie is offline   Reply With Quote
Old 02-25-2013, 10:30 PM   #11
weaintscared
Re: 454 T56 help
I've been buying parts and stuff for my truck for 2 years and someone had told me that I would have to get a special flywheel to make it work, was looking for a part # and who to get the parts from
Old 02-25-2013, 10:35 PM   #12
SS Tim
SS Tim's Avatar
Re: 454 T56 help
The early factory 350 ft lb torque limit would be a start. As I don't have any GVW or GCWR numbers I can't say how well it would work even with only 350 ft lbs input. But remember it was not factory installed in a truck and the O/D ratios are high for a truck.
The transmission has a history of production upgrades that continued long after your 94 trans. and my 99 SS Camaro were built. The late CTS, GTO and SSR transmissions had better sycros (carbon as I recall).
My car had a new 2nd sycro at 7k per GM warranty history and I'd say the trans had been out/apart at least once more after that before I bought it (third owner) at 70K.
From the noise and the fluid I began looking for a replacement or upgrade. About that time the specialist in Houston I was planning on sending it to closed down.
There is probably more info. to be found at Wikipedia on the history. The upgrades can be found in several GM bulletins if you have access but I don't have the numbers accessable tonight.
Take down your numbers, ID what you have. Call D&D for some tech help on making it work but I am pretty sure they are going to say the same thing... upgrade.
Old 02-26-2013, 12:09 AM   #13
Littletony
Littletony's Avatar
Re: 454 T56 help
Here you go, you maybe able to get just the flywheel if that is the only part you are missing.
http://paceperformance.com/i-8690726...6-6-speed.html
"Some people spend an entire lifetime wondering if they've made a difference. The Marines don't have that problem." President Ronald Reagan,1985
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" ..............Eleanor Roosevelt, 1945
Littletony is offline   Reply With Quote
Old 03-05-2013, 08:14 PM   #14
weaintscared
Re: 454 T56 help
Them people are lost they keep tring to sell me a 14" that ain't going to work
Old 03-05-2013, 08:52 PM   #15
SS Tim
SS Tim's Avatar
Re: 454 T56 help
Did you ever talk to D&D? Having the parts to bolt everything together does not make it a good idea.
Old 03-08-2013, 07:30 PM   #16
weaintscared
Re: 454 T56 help
I found aflywheel at American Power Train $389 and a stage 3 or 4 clutch kit 540hp 498 lbtq from GripForce
Old 03-08-2013, 08:07 PM   #17
SS Tim
SS Tim's Avatar
Re: 454 T56 help
Glad you found some parts but from what I know the trans is still the weak link, in fact far weaker than that clutch rating. You really need to talk to a trans builder about the '94 trans you have to see if it is suitable for you use without modification.
EDIT
Just saw that you are double posting this question.
http://67-72chevytrucks.com/vboard/s...d.php?t=567931
Shopping for an answer you want to hear is not in your best interest. Ask a shop that specializes in these transmissions and get an answer on how suitable your current trans is. Having something is a poor reason to install a trans that will likely be troublesome more so if you have to spend a lot to make it work. Having a truck called money pit is one thing but poor uninformed decisions make it one.
