Old 02-26-2013, 07:35 PM   #1
DURG
DURG's Avatar
'02 Yukon/Tahoe front CV Shaft bad? Help.
SERIOUS clicking snapping from the left front wheel area when wheel turned all the way to the left and backing up slow or going forward and slowing for a sharp left turn. Thinking CV joint/shaft. Slight play when pulling on it by hand but not a ton of play. Never worked on one of these before. Any special tools or pullers or anything needed and does this sound like a reasonable diagnosis? Any help/input/tips are appreciated. Looks like just pull the rotor and front hub, split the inboard joint, and pull spindle too? Thanks in advance, Durg.
1962 Impala SS 383 stroker Tremec TKO 600 Black
1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black
2003 100th Anniversary Road King Classic Silver Black
DURG is offline   Reply With Quote
Old 03-01-2013, 12:57 PM   #2
DURG
DURG's Avatar
Re: '02 Yukon/Tahoe front CV Shaft bad? Help.
Put in the new shaft. Same noise.
Old 03-02-2013, 09:48 AM   #3
truckdude239
truckdude239's Avatar
Ball joints or wheel hub
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 03-02-2013, 01:01 PM   #4
DURG
DURG's Avatar
I have 2 new Timken hubs ordered. I changed out front rotors and pads and rear pads today. The rear emergency brakes backing plate/dust guards were rotted and crumbling and a piece was jammed against rotor making a little grinding noise but I still have the same noises so I will wait and see after I change out the front wheel hubs and bearings. I put the grease right to both upper and lower ball joints also. Thanks.
