Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 03-01-2013, 10:11 AM   #1
midniteblues
midniteblues's Avatar
thrid door handle fix
I had problem brakeing my third door handle after i bought this truck back in 04 and just about every winter the handle broke twice I bought one from the dealer that cost me $40-$50 and both broke the winter after i put them in.
so after a google search one nite a few years ago on the problem i came across this handle on ebay iirc it cost somewhere around $5-10 and made very well from aluminum(havent checked latly too see if these are even still availble)
its been on there for a few years now with absolutely no problems.
I just thought i would put this out there for others who might have had the same problem
now if i could only find a good fix for the seatback adjustment handle that seems too be broken on every truck i see.I asked the dealer about this and they recomended a new seat frame at a astronomical price and all i could think was it will last as long as the third door handle
I have/had the "help" replacement handle that basicly gets attached by a set screw(i even added 2 more set screws too the handle an it still wouldnt get tight enough too work correctly) but that didnt last very long before it stripped the splines on the shaft and broke it even more and now i barely have any stud left the best thing i've found so far is a pair of vise grips
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 03-01-2013, 06:41 PM   #2
midniteblues
Re: thrid door handle fix
my title shows why too much coffee is not good for typing...twitchy fingers
Old 03-10-2013, 03:48 PM   #3
71-C10
71-C10's Avatar
After replacing the plastic OEM handle twice, I bought one on ebay made from aircraft aluminum. It seems to be a permanent fix. As far as the seat handles, I bought a set of handles from a seller on ebay called gmseatsolutions09. It fits sort of like you're describing, but mine seem to work good. They come in a set of two for both sides, they have two different ways of mounting, and they come in different colors. Mine are light gray. They are designed to mount on the "broken" shafts. I'm not sure if this is the same handles you have. If not, check them out. He has them listed right now. Replacing the seat mechanism was not an option for me either.
Eddie
71-C10 is offline   Reply With Quote
Old 03-10-2013, 04:31 PM   #4
truckdude239
truckdude239's Avatar
http://www.ebay.com/itm/BROKEN-SEAT-...item2a2a2d3551
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 03-11-2013, 08:44 AM   #5
midniteblues
yhea those are the same ones i had the problem i had was the set screw that tighens against the broken shaft wouldnt hold it tight enough so i added a second set screw too it an then it started too move again an broke the broken shaft some more now theres barely any shaft left hence the vice grips
oh an i found mine at a advance or zone in the discounted "help" items they were like 3-4 bucks apeice
the third door handle works awesome though
Old 03-30-2013, 04:16 AM   #6
Woogeroo
That OEM plastic third door handle is a joke, for sure.
When my folks bought theirs used with about 40 k miles, it was broke, I swapped it out once and my dad swapped it out again.
*sigh*
It still has less than 70 k miles on it... I've been wondering if someone made a handle out of sturdier stuff or not.
-W
Woogeroo is offline   Reply With Quote
