Old 03-02-2013, 03:42 AM   #1
dmack91
dmack91's Avatar
68 C20 to 73-87 C10 front suspension
Is it feasible to swap the entire front crossmember/suspension from a 73-87 C10 into a 68 C20 (yes, I would change the rear to match)? Has anyone done it? Was considering doing a LWB to SWB conversion and this seemed like a natural progression.
I thought there was a thread on the different conversions but couldn't find it.
Thanks for the help.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 03-02-2013, 04:17 AM   #2
EA69TRK
EA69TRK's Avatar
Re: 68 C20 to 73-87 C10 front suspension
Yes you can I believe 2 holes do not line up completely so you will have to oval them. Also here is the thread I believe you were thinking of made my member Lolife99 it's a sticky over in the suspension forum. http://67-72chevytrucks.com/vboard/s...d.php?t=444823
1969 Chevy C10 Short Step -Project
2005 GMC Sierra Crew Cab 1500 -DD
2017 Laguna Orange Roadglide - Good Weather DD
EA69TRK is offline   Reply With Quote
Old 03-02-2013, 04:23 AM   #3
SS Tim
SS Tim's Avatar
http://67-72chevytrucks.com/vboard/s...68&postcount=4
SS Tim is offline   Reply With Quote
Old 03-02-2013, 11:53 AM   #4
dmack91
dmack91's Avatar
That is what I was looking for. Thanks guys.
Old 03-02-2013, 12:08 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Leave the 68 crossmember.
Just clean, inspect, and rebuild the C10 parts,... and swap them over.
Keith
Convert to disc brakes.
Old 03-03-2013, 01:28 PM   #6
dmack91
dmack91's Avatar
LoLife,
In reading your conversion FAQ, it says the spindles can be swapped onto older A-arms with new ball joints and tie rod ends.
Will the newer 73 and up style C10 spindles bolt onto my 68 C20 A-arms, or will I need the C10 arms? If I need the C10 arms, can I swap the entire A arm set-u off of a 73 and up C10 onto my 68 C20 crossmember?
Thanks again
Old 03-03-2013, 01:58 PM   #7
lolife99
lolife99's Avatar
Originally Posted by dmack91 View Post
LoLife,
Will the newer 73 and up style C10 spindles bolt onto my 68 C20 A-arms?
They will the upper arms, with a balljoint change.
The C20 lower arms have a bigger balljoint hole than the C10 version.
So you would need a C10 lower a-arm with the correct C10 balljoint for your spindle.
Will I need the C10 arms?
The lower arm for sure.
YES.
That's what I would do.
You will need all the matching C10 steering components, to make this an easy swap.
Thanks again
Hope this helps^^^.
Keith
Old 03-03-2013, 02:04 PM   #8
Low Elco
Go with the later bushed A-arms. Better ride, easy to build. Lolife is spot-on. Definitely grab the whole late steering assy. At least the center piece. Just did all this to my dads 70using the 70 member. Thanks again for the extermely helpful write up lolife! Easy peasy. If you can get the brake lines, put the 73-up lines in the oval hole in front of the xmember, and use the late hoses. MUCH cheaper and easier to source, plus the combo valve goes down on the frame out of sight. Good luck!
Low Elco is offline   Reply With Quote
Old 03-03-2013, 03:39 PM   #9
dmack91
dmack91's Avatar
Thanks LoLife and Loelco.
Appreciate the help.
