Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 03-07-2013, 09:20 PM   #1
BIG10SILVERADO
Subwoofers behind the seat w/factory located gas tank build.
Here is a mock up of the subwoofers and amp setup in my 56 chevy truck build. Ive searched and could find any one with this kind of speaker setup with the factory gas tank. Subwoofers will be 2 JL Audio 6w3v3s in a ported box. With a JL 700/5 mounted between the subs. Still have to figure out where I want to put the 6x8s.
Gas tank cover and base for the box.
The 2 6 inch woofer and amp mock up
BIG10SILVERADO is offline   Reply With Quote
Old 03-08-2013, 10:16 AM   #2
biohazardbill
Re: Subwoofers behind the seat w/factory located gas tank build.
With that much room.... wouldnt you get more sound with a single 10? I like the design
biohazardbill is offline   Reply With Quote
Old 03-08-2013, 10:26 AM   #3
BIG10SILVERADO
I've measured and measured with the seat installed and I can't even fit 8 inch subs there. The 2 6w3v3 subs will accually be louder then a single 10. And the 6 inch woofers will get pretty low in the "tuned" ported subwoofer enclosure I'm building.
Old 03-08-2013, 01:31 PM   #4
jimmydean
jimmydean's Avatar
I dig it, I haven't heard the 6", but I like the idea of a tuned enclosure to hit low.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 03-08-2013, 03:34 PM   #5
_Ogre
_Ogre's Avatar
big10; check out my interior build link in my sig for an alternative to what you've started.
problem i see with your design is legroom, even if your short.
i have a single 10, 2 amps and my battery behind my seat and i can push the seat back to the window.
shop air compressor timer
Old 03-08-2013, 03:37 PM   #6
_Ogre
_Ogre's Avatar
just re-read your first post, your keeping the stock tank
my enclose won't work for you
Old 03-08-2013, 04:22 PM   #7
BIG10SILVERADO
The design I have now will let me recline seat all the way back with out hitting the woofers. I'm not new to car audio I have built 6th order bandbass boxes with 6 inch woofers that would blow your mind on how hard and clean they hit. But a 6th order is to complexs for this build. Here is a pic of the sub setup I have in my Mercedes. 3 JL 12w3s in a ported box. It's ported thru the back deck so all the bass goes into the cab
