Old 03-12-2013, 07:44 PM   #1
JGross
Lower Radiator Hose for 65 C10 and 5.3L
As you can see from the photo I need help coming up with a lower hose for my radiator. I'm using a stock 65 C10 radiator and the engine is a 5.3L any help would be appreciated.
JGross is offline   Reply With Quote
Old 03-12-2013, 09:57 PM   #2
JGross
Re: Lower Radiator Hose for 65 C10 and 5.3L
Anyone know if the straight thermostat housing made by CRS for the LS1 will fit on the 5.3l?
Old 03-13-2013, 10:20 AM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I had to use one of the aluminum bendable hoses with rubber ends so it would fit, tried several others, even went to get an aluminum exhaust pipe bent but didn't work
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 03-13-2013, 12:41 PM   #4
farmtrucks
farmtrucks's Avatar
I used the ls hose and just shortened it on the motor side.
farmtrucks is offline   Reply With Quote
Old 03-13-2013, 01:35 PM   #5
Wasted Income
Boosted Member
Wasted Income's Avatar
That should work. The truck and LS1 fbody pumps are pretty much an identical casting, and the thermostat housing should interchange.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 03-13-2013, 10:01 PM   #6
TR65
TR65's Avatar
I have a similar situation. It is working but it isn't pretty. My radiator has LS inlet and outlet sizes but not a good location.
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 03-14-2013, 03:42 PM   #7
Hart_Rod
Hart_Rod's Avatar
This is probably the best option out there, unless you spend a lot of hours at the parts store trying to find one with the same bend and correct diameter.
Hart_Rod is offline   Reply With Quote
Old 12-14-2014, 09:06 PM   #8
Jer64
Jer64's Avatar
i used the stock hose from a 2006 truck and cut it down to size, seems to work pretty well. just gets a little tight at the bend.
[IMG][/IMG]
My build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=587028
Jer64 is offline   Reply With Quote
Old 12-14-2014, 10:36 PM   #9
Grandpa54
Grandpa54's Avatar
SEE IF THIS WORK Shttp://www.ebay.com/itm/CBM-10613-GM-Chevy-LS-LS1-LS2-LS7-Billet-Water-Neck-Straight-Thermostat-Housing-/291152423118?pt=Motors_Car_Truck_Parts_Accessories&hash=item43ca0
Grandpa54 is offline   Reply With Quote
Old 12-15-2014, 12:16 AM   #10
scottybaccus
scottybaccus's Avatar
The best fit is a 2010 Camaro water pump. It solves both hoses. The top neck is on the driver's side, allowing a typical GM top hose (I used one from '05-'08 vette), and the thermostat housing is angled downward, allowing use of the LS truck hose. It aligns with truck brackets, no spacers required.
The entire pump assembly is $160 on RockAuto, and includes thermostat, housing and tensioner with pulley. It requires relocating the idler with a $26 kit from Dirty Dingo. You may get by with only the T-stat housing, but the top hose on the truck pump is ridiculous.
Scotty Baccus
scottybaccus is offline   Reply With Quote
Old 12-15-2014, 12:53 AM   #11
HemiChallenger71
HemiChallenger71's Avatar
+1 for this thread!
HemiChallenger71 is offline   Reply With Quote
Old 12-15-2014, 08:35 PM   #12
Willie Makeit
Willie Makeit's Avatar
I used a GATES 21615. I think it's originally for a '98 Cherokee with the 4.0 L6 engine.
I'm running a GEN IV water pump. It may be different for the GEN III.
It has the larger end for the larger outlet on the LS-style water pumps and the smaller end for our year radiators. Cut it to length on the radiator side. You'll end up cutting about half of the hose off.
http://www.rockauto.com/dbphp/x,cata...TES_21615.html
Willie Makeit is offline   Reply With Quote
Old 12-16-2014, 12:09 AM   #13
dayj1
Dayco #71428
dayj1 is offline   Reply With Quote
Old 12-24-2014, 05:40 PM   #14
TR65
TR65's Avatar
Yep, I'm working on the truck on Christmas eve.
This is my third lower radiator hose setup. The last one is shown above, not pretty.
My radiator (Griffin) has a 1-1/2" outlet, same as the LS lower inlet. I looked at the Dayco 71990 hose (late model silverado LS lower) mentioned by Jer64.
It looked like if I could get the LS inlet angle correct the hose would work.
So I got the Mr. Gasket #2670 Swivel housing for LS motors.
I cut 6" off the long straight end of the hose and connected it to the T-stat housing. I cut 1/2" off the short end. That gave a perfect fit. No stress on the hose at all. Here is a pic from on top and from underneath.
There is plenty of clearance and I think it is long enough to allow for engine movement. No leaks so far. Now for the upper.....
1965 C10 SWB Fleet
Two owner
Old 12-27-2014, 09:00 PM   #15
yossarian19
I went to Summit Racing and started using the filters on the left hand side of the screen to zero in on hoses I could use to build the one I needed.
I think I wound up with 3x Camaro hoses & 2x 1.5" Speedway Motors hose-to-hose nipples. Sure, it's a $40 hose by the time you are done. If you can't find an OEM fit hose that is just what you need, though, this is a good option. No kinks, no flow restrictions.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
Old 01-08-2015, 06:19 PM   #16
Gooker928
[IMG][/IMG]
What he said.
Gooker928 is offline   Reply With Quote
Old 01-08-2015, 07:12 PM   #17
scottybaccus
That Camaro water neck will fix that kink in the hose, and can be used on the truck pump.
Btw- when I'm taking about a Camaro pump, it is NOT an f-body pump, and no spacers are required, only the idler relocation...
Scotty Baccus
