Old 03-17-2013, 01:40 AM   #1
70blackfish
where to buy poly motor mounts, small blk?
looking to buy poly motor mounts? for small block
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 03-17-2013, 01:45 AM   #2
HotRod C/10
HotRod C/10's Avatar
Re: where to buy poly motor mounts, small blk?
ebay has them. or pro performance out of arizona, a vendor here.
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 03-17-2013, 01:47 AM   #3
70blackfish
any part numbers?
Old 03-17-2013, 01:50 AM   #4
HotRod C/10
do a search on ebay "SBC Poly MOTOR MOUNTS"
Here I did it for ya.
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
Above link shows the wrong type.
this is what you need.
http://www.azproperformance.com/Prot...or-Mounts.html
http://www.ebay.com/itm/1963-72-Chev...364d2d&vxp=mtr
http://www.ebay.com/itm/63-72-GM-TRU...fdc57d&vxp=mtr
LS SWAPPED
-1976 SILVERADO
Old 03-17-2013, 01:52 AM   #5
70blackfish
I see them now, all that was coming up was side bolt through. mine uses 1 bolt.
THANKS
Old 03-17-2013, 02:03 AM   #6
HotRod C/10
THANKS
I use the one bolt as well. napa had a poly set in stock locally for 80.00.
you can contact pro performance ( a vendor here) and he will give members better pricing especially to a neighboring state.
LS SWAPPED
-1976 SILVERADO
