Old 03-17-2013, 04:45 PM   #1
lgvl
lgvl's Avatar
'82 C30 Speakers?
So my dash speakers are blown and i can't live without having at least partially clear music while i'm driving so of course i'd like to replace them. Well i start flipping through my truck's shop manual and wind up on the speaker section and it shows my truck but doesn't list the speaker size, or at least i didn't see it. So i was wondering if anyone knows the original size? I did the crutchfield lookup and it says 3.5" which makes sense but in the manual it looks like the larger 3.5" was used in a mono center speaker setup while smaller speakers were used in the stereo setup. I'd like to switch to stereo, as it seems i have groovy monophonic sound as of now, so i'm imagining i will have to run new cable to the left and right of the dash cover. So what size are the stereo speakers? Thanks guys.
P.S.- I would normally just go out and remove the dash cover and look but i'm working offshore at the moment and would like to order the parts for when i get home next month.
lgvl is offline   Reply With Quote
Old 03-18-2013, 04:51 PM   #2
85chevy383
85chevy383's Avatar
Re: '82 C30 Speakers?
i just bought two 3.5 inch speakers from the flea market this weekend they seem to be perfect. I dont think anything bigger would fit in the two outside dash holes. The center speaker is oval shaped if i remember right
My 85 build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=497551
85chevy383 is offline   Reply With Quote
Old 03-18-2013, 06:20 PM   #3
lgvl
lgvl's Avatar
Great, that's good to hear. I will be surfing eBay soon!
'82 C30 3+3 Dually 454
Old 03-19-2013, 05:54 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
should be these little guys in the sides
stock is 1-4X10 in the middle,but my left and right are 4X6 now
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 03-19-2013, 06:40 PM   #5
lgvl
lgvl's Avatar
Thanks for the pic, they're really helpful. So the L and R holes are 4x6 stock or did you have to alter them? I only ask because you say "now". Thanks again!
Old 03-19-2013, 08:08 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
my 88 burb had those small round speakers in the corners(gold hole)
the 4X6s (L&R) are replacing a 4X10 stock in my 79 center hole(green )
(it was AM mono one speaker)
here is my build...about post 100
http://67-72chevytrucks.com/vboard/s...=509646&page=2
John
Old 03-19-2013, 10:43 PM   #7
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
The stock stereo speakers (outer holes) in the 81-87 trucks are 3 1/2".
If you had a mono radio it would have a 4x10" in the middle.
For stereo trucks, 4x10s also go in the brackets behind the seats. Any modern 4x10 won't fit because the magnets will hit the cab sheetmetal. You can swap brackets side to side to get more clearance.
An even better solution are Jeff's 6x9 brackets for behind the seats or build your own.
(Link = http://67-72chevytrucks.com/vboard/s...d.php?t=345494)
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
