Old 03-17-2013, 06:47 PM   #1
Knothead
Knothead's Avatar
"02 Z71 rearend noise
My rearend developed a whining noise thats constant. Doesn't change when cornering. Put it on stands in gear, if I stop right side tire it quits. Doesn't sound like axle bearing. Opened cover on rearend,different looking carrier than normal GM. Any ideas on what type carrier it is and possible noise?
Knothead is offline   Reply With Quote
Old 03-17-2013, 08:11 PM   #2
clinebarger
Re: "02 Z71 rearend noise
Pull the axles & check it out, The "G80" Gov-Loc locker is normal on later GM trucks.
clinebarger is offline   Reply With Quote
Old 03-17-2013, 08:16 PM   #3
Knothead
Knothead's Avatar
Are you thinking axle bearing? best bet replace all bearings pinion , carrier & axle or do these carriers problematic?
Old 03-17-2013, 08:46 PM   #4
clinebarger
If its just a axle bearing, Replace that bearing....Got to remove the axle to know for sure. The bearing going bad also damages the axle, Repair bearings are junk...Have the axle welded & machined or buy a new axle.
Old 03-18-2013, 08:12 AM   #5
Knothead
Knothead's Avatar
Thanks, It is the G80. I'm going to tear it down today.
Old 03-18-2013, 08:19 PM   #6
Knothead
Knothead's Avatar
With 225 K on the Ole Gal I guess it was time for an overhaul. The inner pinion bearing was probably the main culprit. There was also pitting on the carrier bearings also. I went ahead and replaced all bearings and seals. I cracked one of the shims for the carrier,are they difficult to find ?
Old 03-18-2013, 10:23 PM   #7
clinebarger
They can be impossible to find in the factory 1-piece version, An aftermarket shim kit will work.
Old 03-19-2013, 05:58 AM   #8
Knothead
Knothead's Avatar
Thanks,I'll try junk yard first, if no luck there then parts store for a shim kit
