03-20-2013, 09:40 AM | #1 |
Cheap Seats
Does anyone in Phoenix have any experience with these seats? The price is very low, but I wonder about the comfort/durability.
http://phoenix.craigslist.org/nph/ptd/3664388149.html |
03-20-2013, 09:48 AM | #2 |
BAD BOW-Silverado XST
Re: Cheap Seats
I would be all over those if I lived closer.
03-20-2013, 09:57 AM | #3 |
Re: Cheap Seats
Looks like a regular dealer is selling them, so why not call him? Shipping can't be that much. When I got the Recaros for my old Honda years ago I had them shipped (from Cali, I think) and they came via freight (truck) and the price was not bad (about $45 I think) - helps if you have them shipped to a commercial address.
Personally, I would have a forum brother in Phoenix put "butt in seat" before I would purchase sight unseen. Of course, the price is what it would cost to have one seat reupholstered. I wonder what he has for mounting hardware/sliders? |
03-20-2013, 11:09 AM | #4 |
Re: Cheap Seats
I am in yuma so i am not too far away, you could have him send you photos with someone sitting in them to see if they appear to have "cushion" or see if its like sitting on plywood. you could probably still try to offer less than the asking, especially as the add gets older.
03-20-2013, 11:21 AM | #5 |
Re: Cheap Seats
Those look like dealer take outs maybe, I bet quality is just fine, looks like a great deal
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
03-20-2013, 11:46 AM | #6 |
Re: Cheap Seats
I talked to the guy at the Pomona swap meet a few months ago. The seats come out of Limo conversions I think it is what he said. I know the H2 middle seat I got came out of a Limo conversion.
I looked at the bottoms, and the way I am going to swap mine in is to cut the sliding base off another bench. Then I will cut the brackets down on my seat then weld them to the C10 base. Those seats like mine are just bolted down to the body in the factory installation. So the body helps set it in the proper orientation when bolted down. So when you have your base set it at the level it sits in your truck. That way you can set it up the way you need/want it. If you just weld brackets to the bench base you'll be low riding. So play around a bit, and see if you want to adjust your height or recline. |
03-20-2013, 12:24 PM | #7 |
Re: Cheap Seats
If you find out that they ship, I want a set. Way cheaper than local boneyards around here!!
03-20-2013, 12:36 PM | #8 |
78K & 79C Jimmys
Re: Cheap Seats
nice ones
I work with disabled people they can also come out of modified vans/trucks etc for wheelchairs a couple i know sent a van to be modified newer dodge with the flip to hide floor seats they knew the foor holes were being removed and the seats but they kept the seats without mentioning it,in the contract when asked they said...."they throw them out", the couple was told didn't take me long to find them for sale,on a local swap site,when confronted they said it was someone selling them out the back door,told fired and sent another set,by courier don't buy the floor flip seats,not comfy,very thin, and ask questions! Van as bought,normal floor nice console MIA, after lowered floor,body raised 5 /floor lowered 6 /total of 11 inches rear seats removed,except at the back these Vans cost as much to mod, as to buy
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
03-20-2013, 12:40 PM | #9 |
Re: Cheap Seats
I just used stock bench seat sliders, and bolted down 1" angle iron between the 2. Then mounted my seats on top. Works quite well.
03-21-2013, 08:21 AM | #10 |
Re: Cheap Seats
Those are second row seats from a Toyota Sienna mini van. They are comfortable, but you may want to go down to a dealer yourself and try first! Also take measurements/pictures to be sure you can use them. Just my advice...........
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD |
03-21-2013, 09:57 AM | #11 | |
been here longer than Liz
Re: Cheap Seats
Reason #3,825 that Oklahoma is better than Texas.
~Greg~ Mac's Garage '87 SWB 6/8 drop "Piso" '08 CCSB Silverado DD the departed '89 GMC K5 Jimmy 4x4 "Rusty Nuts" '77 Chevy K5 Blazer 2wd '83 Chevy stepside "You get what you pay for" - Mike 'swervin ervin' Ervin |
03-21-2013, 09:59 AM | #12 |
Re: Cheap Seats
Good advice. At 56" wide they should be ok. I forget what the inside cab dimensions are, but the back seat of a K5 (between the wheel wells) is 47". Inside wheel wells are what? 6-8" each?
03-21-2013, 10:07 AM | #13 |
Re: Cheap Seats
You can get seats for $40 at the junkyards here also, but they usually have been rotting out in the desert sun for a long time, and subject to insect/vermin invasion. Real nice seats are taken out and kept inside - example: late model Silverado/Sierra seats go for $250/$500 and often need some seat foam/recovering work. Craigslist here is the same - people here want good money for good seats.
03-21-2013, 01:55 PM | #14 |
Re: Cheap Seats
There's a guy on another forum (I've seen him post pics on this forum as well) that converted those same seats (Honda odyssey) to a Square. Came out real nice. Said the same thing, he got em off a guy that was selling them from a wheelchair accessible van conversion.
Posted via Mobile Device |
03-21-2013, 02:08 PM | #15 |
What Hump?
Re: Cheap Seats
I bought a pair and had them in my 78 camper special, motornut was correct when he said they were frm vehicles being modified for wheelchair access.
To mount all I did was take a 2" x 1/8" metal strap shape it to the existing cab mounts, drill and blot the drilled holes for the new seats. I also kept my stock seat belts a pushed them through. They are a tight fit and you cannot use the side cup holder, but I liked them and they matched up pretty good. Tom
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
03-21-2013, 04:30 PM | #16 | |
78K & 79C Jimmys
Re: Cheap Seats
03-21-2013, 04:55 PM | #17 |
Re: Cheap Seats
I bought the Honda Odyssey take out. They fit well but I did have to make new seat brackets.
03-21-2013, 05:11 PM | #18 |
78K & 79C Jimmys
Re: Cheap Seats
they look good,and match well too
03-21-2013, 05:12 PM | #19 |
Charlie Daniels w/ a Tq Wrench
Re: Cheap Seats
Does anyone know if these seats have the LATCH system integrated into the bottom? Would be great to have a new comfy seat option to replace my holy seat in my 78, as well as a safe attachment point if I ever want to take the kid along.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
03-22-2013, 10:23 AM | #20 | |
Re: Cheap Seats
I caught an '01 Burb about an hour after they'd pulled it into the yard. Still had the 3rd row seat in it. I pulled it out, paid $40. I have no doubt that a worker would have pulled it sometime that day and put it on CL for $250. 01+ Silverados never seem to be at the self service yards, and the full service places want $250. Found a guy parting one out on CL, paid $150 for the 40/20/40. Overall $250 isn't bad for seats, but there are better deals out there. Just have to be patient and look.
03-22-2013, 10:25 AM | #21 |
Re: Cheap Seats
Found one set of the Odyssey seats here local, black leather...$600.....yea...no.
03-22-2013, 06:03 PM | #22 |
Re: Cheap Seats
I have the Honda Odyssey seats (3rd from bottom in craiglist pics). I bought them at the Pomona auto swap meet in California. I bought them for around $300. Very comfortable and look great.
03-23-2013, 12:58 AM | #23 |
Spear and magic helmet!
Re: Cheap Seats
I'd like to know what those top 5 sets are in the craigslist ad. I've been looking for a way to retrofit a shoulder belt to the middle for awhile now, and those seats look great. Someone said a Toyota Sienna minivan, I think?
03-23-2013, 07:40 AM | #24 |
78K & 79C Jimmys
Re: Cheap Seats
i can't find the thread @ the site cause it had pictures
but it's a lot closer to Canada(one state away) I'd ask tho did they pay for those seats? or get paid,to take them out? might drop the price
03-23-2013, 01:43 PM | #25 |
Cruzzzn' Vet
Re: Cheap Seats
