Old 06-18-2003, 01:27 PM   #1
BUXMAN66
go bucks!
got a'nutter question....
ball joints ,....both upper and lower's....is the upper joint riveted on from factory and the lower one's pressed in from fact. ?correct me if i'm wrong,trying to line up all the parts/tools needed to complete my front end rebuild.(tie rods,adjusters,idler arm,ball joints,wheel bearings,pitman arm) to go along w/ the dropped coils(3"frt. 4"rear) from mothertruckers.also, what holds the rear coils in place once the rear axle is on jack stands.....is that where the coil cups come into play, as far as holding the top of the coil to the frame,and the lower cup to the trailing arm?? just trying to clarify is all.thanks for any and all replies...... (had to use the new one)!!!
'68 swb 1/2t 350/350th
'86 lngbd 3/4 TON parts getter
'49 gmc 1/2 t 5 window 350/350th
'96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know?
BUXMAN66 is offline   Reply With Quote
Old 06-18-2003, 01:44 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Factory uppers are riveted. Lowers are pressed in. Replacement uppers come with bolts to reinstall, lower replacements require a press.
I removed my lower a-arms and broght them to a machine shop to remove old and install new lower b-joints.
Yes, the rear spring are held in place by those cups.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 06-18-2003, 04:40 PM   #3
ddsmith
Glowing since 1978
ddsmith's Avatar
The lower pressed ones can be a pain. I agree with CNPE that unless you have a large press, a machine shop is the place to go for this.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 06-19-2003, 12:53 AM   #4
BUXMAN66
go bucks!
thanks guys!
