03-22-2013, 06:19 PM | #1 |
Has anyone modified thier core support for donor radiator?
I picked up an extra core support to try it out. I got the donor '08 escalade radiator and fan setup. Seems like if I can modify the core support to make it fit right then I save the headache ( and added expense) of radiator hoses, steam line, tranny line mods. Would make replacement parts easier i think? Has anyone taken this approach?
Shawn Posted via Mobile Device
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
03-22-2013, 11:34 PM | #2 |
Re: Has anyone modified thier core support for donor radiator?
Subed.
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
03-23-2013, 05:24 AM | #3 |
Collector of Projects
Someone used an oversized Dodge radiator and intercooler for a diesel swap but I havent seen the what you're talking about...I think they actually swapped the frame too... I was looking at using the fan from a similar truck.. the dimensions were off.. I think the radiator is both wider and taller....
03-23-2013, 12:22 PM | #4 |
It is definitely wider and taller. I think if I put round holes for the bottom radiator supports I can mount it like the factory mounted it in the newer vehicles. The width will be an issue, but I think I can make it work. I'm thinking that I can move the 'wings' on the core support for the stock radiator out a little bit. Instead of having the radiator be at an angle like stock on the '72, I think I can have it mount straight upright in the core support by slightly trimming the backside of the top Rail of the core support. I would also need to enlarge the opening from the front where the air hits the radiator. I guess we will just have to see.
03-24-2013, 11:25 PM | #5 |
Im running a 02 vette radiator with a set of 02 camaro fans. Just the right hight but narrower i had to trim very little off the top inner lip of the core support. Drilled two holes like you said. Then used two pices of aluminum strap bent with a 90 and drilled holes to go over the top pegs and secure it. The camaro fans need just a little trim to fit the vette radiator. But look like they are made for it. I got the radiator off ebay for 100$ it has oil and tranny cooler built in. Fans cost me 25 bucks from a guy on craigslist parting a v6 car. I used a resivore from a doner caviler
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
10-08-2017, 02:43 PM | #6 |
But Found Her 25yrs Later!
Any progress?
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
10-08-2017, 05:16 PM | #7 |
Ha!
I forgot all about this thread. Yes I had great success. I have 40k miles on the engine swap at this point. I used the stock radiator and fans. I had to do some trimming on the core support, but nothing that takes away from the integrity of the support. I had a cover made out of sheet metal for the top to cover the gap and hold the radiator in place worked out really nice. Hoses are all good.
10-08-2017, 05:28 PM | #8 |
Thanks for the update.
10-09-2017, 12:09 AM | #9 |
Any pictures or link to a thread that already has some?
10-09-2017, 03:10 PM | #10 |
I used an Escalade radiator also..Like they said, just drilled to holes in the bottom of the core support for the mounts. I used some angle to make a mount
and covered it with a piece of 18ga steel. |
10-10-2017, 03:29 PM | #11 |
I used a stock 4 core radiator. No mods needed.
10-22-2017, 11:13 PM | #12 |
BMW & ASE Master Certified
V502, he did a escalade radiator swap on his build.
Clint
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
10-23-2017, 12:11 AM | #13 |
Senior Moment
Same here for my 5.7. I don't get why this is such an issue. Just my 2c
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
