Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 03-23-2013, 12:52 AM   #1
46dogfarm
46 pickup on S10 what rear axle?
Hi, new here. I bought a 1946 Chevy 1/2 ton truck in pieces. no axles, old IH frame. So I am reading all these S10 swaps here and I thinking about it, fits my wallet better. I've got a modified SBC 350 and 700r4 that's destroyed a 10 bolt. So can anyone recommend another heavier duty rear that would fit an S10? My son recommended a 12 bolt.
I also checked www.gmheritagecenter.com and found 1941 1/2 ton specs for the rear end 69 1/8" over wheel hubs and 60 3/8" inner wheel tread. How do these measurements relate to "hub to hub" and "flange to flange" measurements? I don't know what to look at as far as rear axle widths. Mel
46dogfarm is offline   Reply With Quote
Old 03-23-2013, 10:36 AM   #2
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Re: 46 pickup on S10 what rear axle?
welcome to the forum.check out my build page (project moonshine).we used a chevelle 12 bolt.if your motor truly is a tire smoker than you should look into a 12 bolt.i believe it is around 62" flange to flange.other people have used a f*** explorer 8.8.you can pick one up with posi and disc brakes for a few hundred bucks.good luck.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 03-24-2013, 11:47 PM   #3
46dogfarm
Thanks for the suggestions CHIZZLER. If the 8.8 will fit into a '46, just might fit my wallet. 12 bolts are getting well used at this point-probably needing new innards. Your '40 is looking fine, nice write up too! Good to see another in Oregon.
Old 03-25-2013, 12:28 AM   #4
46dogfarm
Well, I got set straight! My son said no F--d in this truck. So I going for the 12 bolt-I do really want his help in this project, even though he's the culprit who blew a hole in the 10 bolt.
Old 03-25-2013, 07:11 PM   #5
CHIZZLER
CHIZZLER's Avatar
12 bolts are getting hard to come by.if your looking for a 3:+ gear then get your wallet ready.i have 2:73 open carrier in mine.im changing to a 3:73 posi and just the parts are $600.let me know if i can help.
61-crew cab D-max
Old 03-26-2013, 11:43 AM   #6
46dogfarm
I''m keeping an eye out. Just setup my blast cabinet over the weekend, got some pipe stuff to build a Franzinator (hope it works) as a water separator. Need to blast those rusty parts. Also replacing the sliding barn doors with an overhead door-sure like your shop front. Nice Suburban and '40 truck -inspiration to keep me going. Mel
Old 03-26-2013, 11:44 AM   #7
solidaxel
solidaxel's Avatar
There is no blue paint on the rear axle, just a different bolt pattern on the wheels, and most people can not see that 1/4' difference. 3:73 disc brakes and a posi makes for a good product, JMTCW
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
