Old 06-18-2003, 04:52 PM   #1
72gmcshorty
72gmcshorty's Avatar
Exclamation Need alternator swap help....
From all the articles posted, there seems to be two different ways of wiring up an internally regulated alternator. I need to know about the one that uses jumper wires over the clip that goes into the regulator. See pic. Once you've attached this piece over the clip, what is done with the remaining wires? There should still be a blue and a white wire leading to the alt, correct? Do these two wires clip into the top of the new alternator (but in a different style clip, correct)? The original red wire that hooked into the back of the original alt is hooked up the same way on the new alternator as well correct? I need this help so that I can get my truck on the road for the first time in over FIVE years!!!
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 06-18-2003, 05:22 PM   #2
racedvl
racedvl's Avatar
I have had mine wired like this for a couple years now, no complains here. . . . . . .
racedvl is offline   Reply With Quote
Old 06-18-2003, 05:43 PM   #3
john
member #16
john's Avatar
One of the wires in your reg. plug should be switched ign. what I did on mine was run it to the field on alt, and get rid of the rest of the wires when I rewired for pass. side alt. My truck has ammeter, not sure if you have warning light. Been workinf for 7 yrs no probs. Good luck hope you get running John
john is offline   Reply With Quote
Old 06-18-2003, 07:19 PM   #4
73stepside
73stepside's Avatar
i took all that wiring out. much easier to run
04 GMC Sierra RCSS
70 CST LWB
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
Old 06-18-2003, 07:32 PM   #5
72gmcshorty
What do you mean took all that wiring out?
1992 Gmc 2wd
Old 06-18-2003, 08:30 PM   #6
john
member #16
john's Avatar
What I did was run the 16brn wire to the field on the alt, and got rid of the rest of the wires. Works good.
oops misunderstood, Yes just pick up a connector for internal alt. and use same wires as before. Parts store should have one. I rewired mine to clean up the engine compartment, but the jumper plug will work okay Good luck.
