Old 03-24-2013, 08:30 PM   #1
Chevette
Chevette's Avatar
Started the interior sheet metal.
With copywrite approval from Shannon, I formed the torque tube tunnel. I will build and install new floorboards and firewall in a couple of weeks.
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 03-24-2013, 08:35 PM   #2
Chevette
Chevette's Avatar
Re: Started the interior sheet metal.
A couple more and I bought a new rad.
56 Chevy PU
Old 03-24-2013, 08:36 PM   #3
xpickup
xpickup's Avatar
Chevette, Boy, it is about time. Tunnel looks great. I also love the dimpled holes on the cross brace. I need to make some dimple dies at work. They look great too. It has been so long not seeing your truck, you have to post more pictures. Great job.
Shannon
xpickup is offline   Reply With Quote
Old 03-24-2013, 11:45 PM   #4
Kim57
Kim57's Avatar
Very nice.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-25-2013, 06:24 PM   #5
Chevette
Chevette's Avatar
Thanks Shannon. I bought the dimple dies on eBay. They are from a company in Texas. If I remember correctly, it was Kim that put me onto them. They are well made and the price was decent.
Thanks Kim. BTW, my chassis will be ready for brake lines in about a month. Let me know if you have time......Hahaha!
56 Chevy PU
Old 03-25-2013, 06:45 PM   #6
hotrod1
56 - autocross
hotrod1's Avatar
I bought the same ones. Barbed wire off road. Their product is usually on top on a camouflaged background. Very nice to work with and a very good product.
hotrod1 is offline   Reply With Quote
Old 03-25-2013, 06:49 PM   #7
Love2Fab1
Very nice! Looks very precise and well fit. Hope to use a similar style of channel to reinforce our hood.
Fab1
Love2Fab1 is offline   Reply With Quote
Old 03-26-2013, 12:14 AM   #8
Kim57
Kim57's Avatar
Just bring to my garage and it's no problem.
Kim
My build thread
Old 03-26-2013, 07:58 AM   #9
FarmerSid
FarmerSid's Avatar
Nice fab work! Real nice! What thickness of material are you using if you don't mind me asking?
FarmerSid is offline   Reply With Quote
Old 03-26-2013, 08:51 AM   #10
Chevette
Chevette's Avatar
Thank You FarmerSid. It's 18G.
56 Chevy PU
Old 03-26-2013, 09:41 AM   #11
FarmerSid
FarmerSid's Avatar
Thanks Chevette. I have tons of old shelving unit shelves that I plan on using for my 52 rebuild. They measure 0.043" which is between 18 and 19 gauge. There are factory 90 degree bends on them that I cut off the perimeter so all I am left with is a flat sheet about 32"X20". I bought a shrinker stretcher and tried to shrink a piece of the 90 deg cut offs. It's almost like the metal I'm using is too thick for the shrinker. I'm afraid I'm going to break it with the amount of force I am applying. The metal is barely shrinking and I only inserted the metal about half way into the jaws.
Old 03-26-2013, 06:40 PM   #12
Chevette
Chevette's Avatar
Must be a harder steel. I have a shrinker/stretcher and it shrinks 18G with no problems. I set up the jaws as per Lazze. See video:
56 Chevy PU
Old 03-26-2013, 07:00 PM   #13
Kim57
Kim57's Avatar
This is some 16 gauge that I did with the cheap Harbor Freight shrinker/stretcher. One inside curve and one outside then welded together.
Kim
My build thread
Old 03-26-2013, 08:23 PM   #14
Chevette
Chevette's Avatar
Kim
Kim: You can achieve the same thing with a single piece if you shrink one side then stretch the other. Shrink a few times on one side the stretch a few times on the other....back and forth....back and forth. I have done it with 18G. and it worked great. I don't know how well it would work on 16G though.
56 Chevy PU
Old 03-26-2013, 09:22 PM   #15
xpickup
xpickup's Avatar
Sometimes if it does not seem like it is moving I only insert into the stretcher or shrinker half of the way. I do it a few times and then go back in to the full depth. Also if it seems like it is not moving I clean the dies.
Shannon
Old 03-26-2013, 09:37 PM   #16
Kim57
Kim57's Avatar
I'm new at this part of fabbing things up. That was the first time I used the tool. I'll have to experiment with it when I get back to the body work.
Kim
My build thread
Old 03-27-2013, 08:00 AM   #17
FarmerSid
FarmerSid's Avatar
http://www.youtube.com/watch?v=DEYpn6PkDcg
Thanks Chevette! I have watched that video as well many others by Lazze. I have done to my shrinker/stretcher as he recommends. It is now apparent that I need to come up with a foot operated stand. The shrinker/stretcher I have is from Woodward Fab.
Old 03-27-2013, 09:17 PM   #18
mknittle
mknittle's Avatar
Chevette looking good! Making mine look like more like a turd every day. I am getting restarted next week. My dad has had the shop tied up with his 1940s Peterbilt pickup project.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 03-28-2013, 08:39 AM   #19
Chevette
Chevette's Avatar
Good to see you're getting back at it. I look forward to the next plasma cutting tutorial. Tell you're father to get his truck out of there. BTW, there are no turds.
56 Chevy PU
Old 03-28-2013, 09:24 AM   #20
dubie
dubie's Avatar
that my friend, is some fancy tin bashing. Nice job!!
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 03-29-2013, 11:06 AM   #21
chevyrestoguy
chevyrestoguy's Avatar
Nice job on the sheetmetal work on the floor! You nailed the shape and the fit perfectly. The use of the slip roll and the dimple dies looks awesome. It would almost be a shame to cover it all with carpet!
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 03-29-2013, 08:42 PM   #22
Chevette
Chevette's Avatar
Thanks for the kind words, Chevyrestoguy.
I got a little more done today (but not much).
56 Chevy PU
Old 03-29-2013, 08:58 PM   #23
Wheelie
Great looking fab work. I love me some dimple dies!
My '59 Build Thread
Wheelie is offline   Reply With Quote
Old 03-29-2013, 09:12 PM   #24
hotrod1
56 - autocross
hotrod1's Avatar
How did u do the dimples in the curved piece? Dimples first then rolled it?
Old 03-29-2013, 09:35 PM   #25
Chevette
Chevette's Avatar
I drilled the holes, then rolled it, then dimpled the holes. I used a narrow anvil to sit the lower die on in the press, that way the there was plenty of clearance so the piece didn't bind against anything that would cause it to straighten out. Hope that makes sense.
56 Chevy PU
