Old 03-27-2013, 01:19 AM   #1
MrBeast
high-Tech Red Neck
MrBeast's Avatar
How about a 52 Chevy Dually 4x4 Welding rig?
I've been thinking about starting another project when I get up to Montana this summer.
I found this puppy for sale on craigslist.
I have been looking around, finding lots of parts, been thinking about what I could put together with it. What I am envisioning is a fuel injected big block, NV4500 with a 205 or dana 300 and a Dana 44 and a Dana 60 up front and a P30 14 bolt out back.
I was thinking some twinkie truck 19.5's
and one of these puppies on the back on a custom made welding bed.
I have several options I am considering, one is taking a 88-98 1 ton dually that already has the 5 speed and 454 then sectioning the cab from the 52 over the floor and firewall from the 88-98
Another is simply just moving everything over to the 52 and building new spring hangars and what not to make everything fit.
I had also thought about seeing what it would take to make a 12 valve Cummins fit, These old trucks I know the hoods are fairly long, it might squeeze in. I don't know anyone who has done it so far.
Right now this is all just food for thought, it would be a neat build if I built it.
Thought you guys might get a kick out of looking at it.
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 03-27-2013, 06:17 AM   #2
xpickup
xpickup's Avatar
Re: How about a 52 Chevy Dually 4x4 Welding rig?
MrBeast, I think that would be a great build. Hate to see your daully cut up though. I wish mine was a 2wd 4 door.
Shannon
xpickup is offline   Reply With Quote
Old 03-27-2013, 07:06 AM   #3
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Shannon
I won't be tearing one of mine down to build this if I do I will be buying a parts truck, I found an 86 4x4 that has a utility bed on it. The truck is pretty rough so it is ripe for parts.
Old 03-27-2013, 11:02 PM   #4
Trekster
Trekster's Avatar
That is kinda what I would like to do with this truck that I just drug home. I now need to find a 1 ton 4x4 dually donor truck.
Trekster is offline   Reply With Quote
Old 03-27-2013, 11:23 PM   #5
Chevette
Chevette's Avatar
Great idea! Have a look at these.The 48 looks in decent condition. A COE would be cool with a Cummins if you could find one at a reasonable price.
http://cgi.ebay.com/ebaymotors/1948-...item27d13eb023
http://cgi.ebay.com/ebaymotors/1948-...item1e78c19d30
56 Chevy PU
http://67-72chevytrucks.com/vboard/s...d.php?t=531955
Question: Know how to sell your truck for $50,000?
Answer: Spend $100,000 building it.
Chevette is offline   Reply With Quote
Old 03-27-2013, 11:41 PM   #6
MrBeast
high-Tech Red Neck
MrBeast's Avatar
That first truck is a rusted out turd!
The 2nd one is cool but needs a lot of finishing. I am not very hot on how they did the floor boards.
It would have been much more advantageous to build a new plenum with a front intake to keep the floor board wider.
I am 6'1" 300 lbs, sitting with my right leg tucked up against the steering column doesn't sound very comfy.
Old 03-27-2013, 11:42 PM   #7
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Cool! we need to see a build!
Old 04-10-2013, 03:59 PM   #8
Truck Guy99
I saw this on welding web. I'm 1955_Chevy_6400 on there. Let us know how it goes!
Truck Guy99 is offline   Reply With Quote
Old 04-14-2013, 08:23 PM   #9
joe tx
I started building a service truck for the shop, but my son decided he needed it so now we're building this for my son as his welding truck....'54 6600 on a '92 3/4 ton dodge chassis with 5.9 auto, 2 wh. dr.... Soon to be 4 wh. dr. Took off the utility bed and we are putting a welding bed with a dual wheel one ton cab and chassis rearend and front end.
Cummins fits. Actually had to move the stock motor mounts back about 4 inches as I had too much space between the back of the engine and firewall. This gives me enough room for the radiator and inter cooler....Joe.
joe tx is offline   Reply With Quote
Old 04-15-2013, 12:00 AM   #10
MrBeast
high-Tech Red Neck
MrBeast's Avatar
Joe, very cool truck!
Right now I am not going to pursue this project, I was thinking about it but I really need to get my 72 finished first.
Been updating it pretty heavy if you guys are interested:
http://67-72chevytrucks.com/vboard/s...d.php?t=278230
Old 05-12-2013, 09:23 PM   #11
Truck Guy99
Any new updates? This is a cool build!!
My names Tye. No Chevy right now
