![]() Join Date: Nov 2007
Ho52 axle
I have a 72 3/4 ton full float HO52 axle for free. local pickup maryland and she's yours. It's in great shape and has 4.09 gears. I also have a 350 small block 4 bolt main that has been rebuilt and is in good shape with performer aluminum intake, rochester 4 barrel carb and new elec choke. $250.00.
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636 Easier to beg forgiveness than ask permission! ![]() |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: Ho52 axle
Wish you were closer, dang it
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
Re: Ho52 axle
Does the ho52 have a locker or posi? If it does I'm interested.
Posted via Mobile Device |
Re: Ho52 axle
Have not opened it up but shafts spin in opposite directions.
I will look back at build sheet. And verify Posted via Mobile Device
Re: Ho52 axle
Build sheet lists it as no spin rear axle. So I'm pretty sure it's
Posi Posted via Mobile Device
![]() Join Date: Oct 2007
Re: Ho52 axle
I'm interested in the Rear Axle and live by Gettysburg, PA so I could pick up tomorrow or Saturday.
Would that work? Alan |
Re: Ho52 axle
tomorrow anytime or saturday in early afternoon would work.
I'll send you a message on forum with details. Chris
Re: Ho52 axle
I'm interested in both,if by some rare chance the axle becomes available. What is the engine code?
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 04-04-2013 at 09:54 PM. |
Re: Ho52 axle
The axle will likely be picked up today. The motor is still available and engine code pictured above. Or, it's listed as 3970010 350 69-79 Truck 2&4 bolt main. This block
is a 4 bolt main and ran very strong when truck was on the road. I also have an HEI distributor new in box somewhere that I'll take $250.00 for as well if anyone needs it. Let me know. Chris
Re: Ho52 axle
The engine code is stamped on a pad on the block that extended past the head mounting surface. That embossed number is the casting number. All that lets me know is it's a 350. The engine code will have letters for a prefix and that number lets me know what the engine came out of and other specific info. I would have bought the engine no matter what the code if I had caught the rear,too. Still interested in the 350 if the numbers are what I'm after. Thanks for checking.
Re: Ho52 axle
OK special k. I'll get ya the other number today and shout back. Also , the axle has a new home as of yesterday.
Chris
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636 Easier to beg forgiveness than ask permission! ![]() Last edited by cmabolt; 04-06-2013 at 08:41 AM. |
Re: Ho52 axle
hey Special K. The engine ID is VO412TRK
Let me know if still interested. I also have all accessories for motor including, brackets, starter, pwr steering, alternator, water pump and orig AC comp. I also have the entire AC system which worked when uninstalled, but will need mo money for that. chris
#13 |
Re: Ho52 axle
Thanks for the info,Chris. That's a truck 350 from either a '72 K/20 with manual trans or '73 C/20-30. I have questions on the rebuild and I think we should talk on the phone. I'm sending a PM now.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 04-07-2013 at 10:02 PM. |
#14 |
Re: Ho52 axle
Motor and axle sold
