Old 04-09-2013, 01:15 AM   #1
spencer_41188
spencer_41188's Avatar
sloppy steering
found a nice fix to the slop steer
after looking at all the frame, rod ends and adjusting the steering box what more can there be...
the rag joint ... after having a buddy turn the wheel and I looked at the rag joint. it was bad ... good thing for safety studs
the fix is a 90's jeep Cherokee steering shaft. it used 2 u-joints instead of the rag joint and ball and socket joint. all I had to do is collapse it enough to fit and ream the steering column so the bolt would go threw
the price $2.00 to get in to the pick a part, $8.99 for the steering shaft and taxes so for around 12 bucks you can ditch that rag joint
88 gmc v3500 bonus cab classy chassy conversion, 454, nv4500, np205, dana 60 front with spool, 14 bolt ff cac rear with locker.
spencer_41188 is offline   Reply With Quote
Old 04-09-2013, 01:22 AM   #2
JellyBeanDriver
Re: sloppy steering
Please post photos when you're done.
JellyBeanDriver is offline   Reply With Quote
Old 04-09-2013, 01:36 AM   #3
spencer_41188
Re: sloppy steering
not too shabby
Old 04-09-2013, 02:00 AM   #4
spencer_41188
Re: sloppy steering
this is where I got the idea and did some research
http://www.polyperformance.com/shop/...ft-p-2125.html
Old 04-09-2013, 11:52 PM   #5
JellyBeanDriver
Re: sloppy steering
Thanks!
86' C30 Dually Crew Cab Ranch truck, carb'd 454, TH400, towing a slant load 4 horse trailer.
