Old 04-10-2013, 12:48 AM   #1
1tonchevy
C35 Crew Dually
1tonchevy's Avatar
checking trans fluid
Got a Th400 in the big dirty whats the "procedure" for checking the fluid 15 min run (to get it to operating temp) put it in neutral on flat solid ground?
just want to get a good reading that's all.
Thanks Dru
If it aint square, I don't care.
84 C35 CC Dually Project log...
http://67-72chevytrucks.com/vboard/s...d.php?t=414892
1tonchevy is offline   Reply With Quote
Old 04-10-2013, 12:56 AM   #2
rollin thunder
rollin thunder's Avatar
Re: checking trans fluid
just get to operating temp and Check it while in park is and flat surface is fine. I run through the gears once just as an extra thing. and each time I add fluid i run through the gears and wait for a few minutes for any fluid on the side of the tube to drain down so as not get a false reading. remember DONT overfill and use proper fluid as always!
My build Lil` Red http://67-72chevytrucks.com/vboard/s...d.php?t=551373
1984 Chevy C10 short bed
2001 Chevy Impala police cruiser
2001 Chevy Silverado 1500 Z71 4wd extended cab dd
rollin thunder is offline   Reply With Quote
