Old 04-10-2013, 01:24 PM   #1
NewType72
NewType72's Avatar
Post Alignment issue
On my 72 my left front wheel tucks in at the top causing me to pull and eat away at the inside of the tire.
I've maxed my limit on the stock studs for the upper a-arm spacing so I can't push it out anymore at the top is there a simple way to fix this issue so that my front end can be aligned properly once again?
Was thinking a longer stud in its place and washers or make a billet solid shim so that there's no chance of the shims falling out after installed.
Any ideas? I'm focusin my money to put in a new motor so I can't put a ton into new arms or anything.
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 04-10-2013, 11:15 PM   #2
Robznob11
Robznob11's Avatar
Re: Alignment issue
Is the truck dropped? wheel bearing good?
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 04-10-2013, 11:21 PM   #3
NewType72
NewType72's Avatar
Re: Alignment issue
Lowered slightly. Wheel bearing should be fine a lot of suspension steering parts were replaced two years ago
- Dylan
(209)-985-7721
Old 04-11-2013, 04:44 AM   #4
wraprail
wraprail's Avatar
Re: Alignment issue
Moog makes an offset upper control arm shaft for many car and truck models. While I do not know if yours is included it would be worth checking into.
wraprail is offline   Reply With Quote
Old 04-11-2013, 10:27 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Alignment issue
How is it lowered? Give us more details please. There is no reason why you should not be able to get back in specs after a mild lowering.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-11-2013, 10:47 AM   #6
BMERDOC
BMERDOC's Avatar
Re: Alignment issue
Most times inner or outer tire wear is associated with toe. Its not hard to assume that tire wear like this is caused by excessive negative camber. As long as the negative camber does not exceed -1.5° tire wear would be a negligible. Have you had a recent alignment. If so, do you have a copy of the results?
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
a-arm, alignment, shims, spacing, stud
