Old 04-12-2013, 03:03 PM   #1
1987chevyv10
sm465 gear ratios
I'm new to this forum and this will be my first post. but I just picked up a 1987 Chevy v10 with the sm465. does anybody know what gearing they have from the factory? thanks
1987chevyv10 is offline   Reply With Quote
Old 04-12-2013, 03:08 PM   #2
Wellgeo03
Wellgeo03's Avatar
Re: sm465 gear ratios
Got these numbers off a gear ratio calculator site, so take them for what you will.
1st: 6.65
2nd: 3.58
3rd: 1.70
4th: 1.00
Not sure if you had a miss type, but to the best of my knowledge GM has never had a V10 eingine...
Wellgeo03 is offline   Reply With Quote
Old 04-12-2013, 03:11 PM   #3
1987chevyv10
1st: 6.65
2nd: 3.58
3rd: 1.70
4th: 1.00
thanks! and it isn't a v10 engine, started in 1987 they used r/v instead of c/k so it's just a k10
Old 04-12-2013, 03:13 PM   #4
Wellgeo03
Wellgeo03's Avatar
Oh, yep, I completely miss read that part!
Old 04-12-2013, 03:14 PM   #5
Turbo85GMC
Turbo85GMC's Avatar
I think the original poster means "V10" to be a R/V series truck.
I think they changed the model numbers in '86 or '87 from C/K to R/V.
Anyway, welcome to the SM465 club! I have yet to find an on-road use for first gear! If 1st and 2nd were synchro, I would swap out the rear end to a 2-something ratio and drive it like a 4 speed instead of a 3 speed.
'85 GMC 1500
"Friends don't let friends drive stock!"
Turbo85GMC is offline   Reply With Quote
Old 04-12-2013, 03:23 PM   #6
1987chevyv10
thanks! what's the rear end from the factory? right now it has 35 inch tires on it and it seems to need a little lower rear end
4 speed, gears, k10, ratio, sm465
