04-15-2013, 09:28 PM | #1 |
Does anyone spray rust preventer ....
between their rockers and also inside the doors? I am going to be spraying some SEM rust preventer in between the rockers and also inside the new doors. http://www.semproducts.com/product-c...ust-preventer/ I figure this is a little extra insurance so it will stay nice for awhile.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
04-16-2013, 12:02 AM | #2 |
Junior Member
Re: Does anyone spray rust preventer ....
It sounds like a good idea to me. We did that when we did the build on my '67.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
04-16-2013, 04:15 AM | #3 |
Yes! I filled every hollow space in mine.
Doors, cab corners, rockers, fenders, bed sides, etc. I did this with Tectyl ML. Don't know if you can puchase that in the US but it's probably almost the same stuff as SEM's. Best you can have is Mike Sander Fett. But hard to come by in the States I guess and pretty hard to apply. (Google it) Just pour it in every hollow space you can imagine until it flows out of the holes. This way water can't stay anywhere. I live in a very wet climate with salt on the roads during the winter, so I have to do the best I can. You can see the drips in my door: |
04-16-2013, 06:19 AM | #4 |
May sound retarded but i flex sealed my truck... That's how she's black
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
04-16-2013, 07:08 AM | #5 |
04-16-2013, 07:16 AM | #6 |
BAD BOW-Silverado XST
I use Zero Rust for protection. Works better than POR-15. My engine bay, frame and suspension are holding up very well.
04-16-2013, 07:28 AM | #7 |
X2 on the zero rust. Anywhere I could fog it, roll it or brush it in
04-16-2013, 07:30 AM | #8 |
We are talking about hollow spaces right? For hollow spaces you need a waxy of fat kind of stuff. That por-15 holds up good on your frame doesn't say that it is enough for the inside of your doors.
Best way is to give it first a coat with something like por-15 or any other kind of rustpreventive paint. (difficulty is to get it properly in the hollow spaces). Second is a coat of wax or fat, like SEM's Throw this article in Google Translate. It's a research on hollow space rust prevention. http://www.autobild.de/artikel/rosts...est-35817.html |
04-16-2013, 08:18 AM | #9 |
78K & 79C Jimmys
My trucks have had pro oil sprays done,works but messy
but I use up tremclad spray cans and empty/finish them up on bottom side fog into holes i can get too
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
04-16-2013, 09:16 AM | #10 |
I'm going to use a wax product sold by eastwood for the bottoms of my doors, rockers and cab corners.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
04-16-2013, 05:13 PM | #11 |
I just picked up some cheap 3m undercoating/sound deadened and coated the inside of my doors last night. My new aftermarket window seals totally suck so my doors always have water in them, which worries me. I also bought speaker baffles for mounting my new 6x9s in my doors, so they won't get wet.
1976...no...79...Chevy....wait...GMC shortbed 4x4. 5 inch lift on 35s, 355, sm465, daily driver. One day I'll figure out the story in that one. 1957 Chevy long stepper...not sure what I'm doing with that one yet. Awaiting funds I suppose. |
04-16-2013, 06:33 PM | #12 |
Is there a way to get some kinda rust protector into the rockers where they always seem to rust out? If not I was going to drill holes when I replace mine on the underside and put a removable rubber plug. That way I can get in there and spray some fluid film or something in there to keep the new rockers from rotting out. I was also thinking of doing this from the inside to get some in the cab corners where they rot out.
04-16-2013, 09:02 PM | #13 | |
04-16-2013, 10:33 PM | #14 |
I'd never use tectyl, Brockway used that in their 700 series cabs in 75-77 and the only part of the cab/doors that didnt rust, was where the sticker was! Kinda like Rusty Jones.... lol
Jeff Shaw 2003 Chevy 2500HD LB7 Duramax |
04-16-2013, 10:45 PM | #15 |
75chev4x4, Not sure if you can get to it without removing or pulling out the bottom of the fender. But here is the plug on my 85 with the front end off.
04-17-2013, 03:00 AM | #16 | |
Tectyl ML works pretty good. You do have to spray it over a little each year though. Tectyl underbody coating sucks. It cracks and rusts underneath. It is also very hard to get off. With a spray straw you can reach every place you want. For the Tectyl it's like 25" long. |
04-17-2013, 09:54 AM | #17 |
i used sound crap in my diesel in the doors and the rockers as best i could just made sure the holes are cleard for draining. so far so good
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
04-19-2013, 12:38 PM | #18 |
04-19-2013, 11:11 PM | #19 |
Old engin oil mixed 10 parts oil to 1 part kerosene will penetrate the seams in doors rockers and cab corners, works a treat.
77 Cheyenne no longer in bits |
