Old 04-16-2013, 10:26 PM   #1
bob_o
bob_o's Avatar
Steering Column Question
I bought a late 70's/early 80's tilt for my '75 Sierra and had it shipped to me. When I unpacked it, I saw that the splined steering shaft had collapsed, presumably during shipping since the box was all jacked up. The rest of the column appears to be fine...
Here's the question: Can this shaft be pulled out? Or did Fed Ex (and the seller's packing) cost me $125? Thanks!
bob_o is offline   Reply With Quote
Old 04-17-2013, 07:47 AM   #2
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Steering Column Question
I'd like to be funny and say i think you go the shaft!
but i really think you didn't....(get the lower half)
one style has outside clamp,another bolt going threw it
don't think it would all tuck up there
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 04-17-2013, 01:37 PM   #3
bob_o
bob_o's Avatar
Haha, thanks. So there's nothing wrong with the column? I just need to get the clamp style "lower" shaft?
Old 04-17-2013, 02:59 PM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
I'm sure the spline should be out,with a flat side
John
Old 04-17-2013, 03:03 PM   #5
Turbo85GMC
Turbo85GMC's Avatar
I had that clamp off before, and yeah, that spline part should stick out further.
'85 GMC 1500
"Friends don't let friends drive stock!"
Turbo85GMC is offline   Reply With Quote
Old 04-17-2013, 07:40 PM   #6
bob_o
bob_o's Avatar
I figured as much. So can it be pulled back out to where it should be?
Old 04-17-2013, 08:05 PM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
I know they collapse some, but not there,not with the clamp on
I know when removed from the steering box the
solid part will slide up the space from the rubber to the clamp bolt
enough to replace rag joint!
(better pic ,missed the green arrow in the dumbnail lol)
John
Old 04-18-2013, 02:06 PM   #8
bob_o
bob_o's Avatar
Ok, I feel like I'm not explaining myself well enough... Lemme try this again.
The red arrow indicates how much of the splined shaft should be showing:
The blue arrow shows just how much of the splined shaft on my column has collapsed:
My question: Is there a way to pull it back out to the appropriate length?
Old 04-18-2013, 02:34 PM   #9
Katrina/10
Katrina/10's Avatar
What does the end the steering wheel attaches to look like?
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 04-18-2013, 02:39 PM   #10
INSIDIOUS '86
INSIDIOUS '86's Avatar
Take off that bearing retainer on the tip and pull out the shaft with pliers. You should be good to go then
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 04-18-2013, 05:02 PM   #11
bob_o
bob_o's Avatar
With the exception of the tilt feature, it looks near identical to my existing column.
Ok, I'll give it a shot. Thanks
Old 04-18-2013, 07:08 PM   #12
motornut
78K & 79C Jimmys
motornut's Avatar
if you get the shaft and the clamp, slide it on a bit, tighten and pull
I'd ask seller if it was like that
or did that get dropped causing that
never had to pull it out , not sure
I'm still wondering why it's in !
John
Old 04-18-2013, 11:19 PM   #13
INSIDIOUS '86
Looks like the top shaft is poking out too so the whole assembly may be jogged up
Old 04-18-2013, 11:46 PM   #14
motornut
78K & 79C Jimmys
motornut's Avatar
yup I didn't see that top pic
normally that little clip is in a ridge up against the lock ring
usally hard to remove,I'd take those top parts off make sure stuff is ok inside
top center looks a little beat on but i've seen a lot worse
does it tilt ok?
John
Old 04-19-2013, 03:30 PM   #15
bob_o
bob_o's Avatar
I pulled the bearing and retainer off to try pulling the shaft out some, no luck. Maybe If I try tapping the sfatf from the steering wheel end using a rubber mallet?
Yep, it tils just fine, everything is tight. Turn signal cam is in good shape too.
Old 04-19-2013, 04:56 PM   #16
motornut
78K & 79C Jimmys
motornut's Avatar
push down steady on the floor?
John
Old 04-19-2013, 04:57 PM   #17
motornut
78K & 79C Jimmys
motornut's Avatar
John
