Old 04-17-2013, 07:16 PM   #1
Hazieview
Building Dreams out of Dimes!
Good grief how long does it take to bleed a brake system?
I converted my rear brakes from drum to disks. I tried for a good hour with the wife pushing the brake pedal and didn't get a drop out of the rear brake lines yet. Perhaps it takes longer than I expected....?
1981 Chevy short/wide.
SB400 350th
Hazieview is offline   Reply With Quote
Old 04-17-2013, 08:19 PM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Good grief how long does it take to bleed a brake system?
We were just having this discussion here:
http://67-72chevytrucks.com/vboard/s...02#post6017202
Similar issue, perhaps?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 04-17-2013, 08:22 PM   #3
Rubble
It's possible the proportionating valve has slid over & not allowing fluid to rear.I just went thru similar thing on my 82 K25 when I replaced wheel cylinder.You need to bleed the front right hand side first to get the valve to slid over,then you should get fluid to rear.Unless it's like mine was,ended up replacing master cylinder as well.
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 04-18-2013, 10:08 AM   #4
Hazieview
I have an adjustable Willwood proportioning valve so that shouldn't be the issue. I wonder if my master cylinder is bad....?
I expected to see the fluid level in my master cylinder to drop a little more rapidly. However, it seems to be dropping very very slow, if any....
SB400 350th
Old 04-18-2013, 01:31 PM   #5
Rubble
I was getting a small amount of fluid at rear axle,but very little pressure.Swapped m/c out off a parts truck & all kinds of pressure now.That might be your trouble too...My fluid level in old m/c didn't drop much either..
