Mongrel truck
Hello
Thank you in advance for any help or comments. I am new to this forum . I have been reading a lot , but cannot find the right info. Here is my story. I received a truck a few years back. I let it sit in the backyard for a time. It is , I was told a 1979 cab on a 1987 frame, with a home made dump body on it. It is a 4x4. The motor is a 305 with a overdrive transmission. The truck does not have lock out hubs. It is tbi. I have started to work on this truck. I want to fix it up a little . The cab and frame are in good shape. The motor. And other mechanicals are a bit rusty. I have replaced the brake,power steering and transmission cooler lines. I have not been able to get the motor running correctly. I am looking for a picture or diagram with the various control parts and vacuum lines on it . On this truck the water temp sending thing is on the front of the manifold. I assume the throttle position sensor is on the passenger side bottom of tb. What does the egr do? Does this truck have a computer and if it does where is it? The wire that you disconnect to time the motor, if I disconnect it the truck won't start. What I need to do is identify all the pieces first. Posted via Mobile Device |
Re: Mongrel truck
It has a computer, or TBI won't run. It's behind the glovebox, silver box thingy....Timing I think is a brown wire.
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
Re: Mongrel truck
Thanks just gathering info right now.
Re: Mongrel truck
Can someone tell me what the first year for fuel
Injection was ? Posted via Mobile Device |
Re: Mongrel truck
as far as i know, it was 1987.
1977 srw cc lb 396/700r/4:11's/6'' bds lift/ 35's. sold 1986 suburban 350/700r/3:73's 31's: parted out. 1980 silverado swb 5.3/700r/ 2'' drop/ daily driver. sold 1985 c10 long bed 5.3/700r/2'' drop/17" wheels/ daily driver. sold 1970 c10 long bed-new project! getting ready for the 6.0 |
Re: Mongrel truck
Thank you PW
Your in windsor locks ? i live just south of middletown. I am trying to get this truck running decent, One thing leads to another !! |
Re: Mongrel truck
that's cool, i used to live in middletown. i know how that "one thing leads to another" thing goes! good luck and keep at it.
