Old 04-19-2013, 10:09 AM   #1
rs74
rs74's Avatar
My ignition turns without the key.
Can I fix this or do I just need to put in a new lock cylinder. If I can fix it then I would just assume do that but not sure what would need to be done to it. This is just one of the little things I want to fix before I put the truck back together.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 04-19-2013, 10:10 AM   #2
Gigem
Gigem's Avatar
Re: My ignition turns without the key.
need a new lock cylinder - yours is worn out. so was mine...
1972 GMC Sierra Grande (current truck)
1980 Chevy Stepside (gone)
1987 Chevy Blazer (gone)
1972 Chevelle SS Convertible (gone)
1973 Chevy Corvette (gone)
1967 Chevy Camaro (STOLEN!)
Gigem is offline   Reply With Quote
Old 04-19-2013, 10:14 AM   #3
rs74
rs74's Avatar
How hard is it to replace on these columns. I have changed a few out but never on one of these.
Roy
1987 R10 shortie
Old 04-19-2013, 11:33 AM   #4
Low87
been here longer than Liz
Low87's Avatar
It's pretty easy, just need a wheel puller. Probably a 30-45 minute job.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 04-19-2013, 12:23 PM   #5
meatwagon83
meatwagon83's Avatar
you and about 80% of the rest of these trucks
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 04-19-2013, 01:40 PM   #6
Rufton
Sounds like something to keep on the down low.
Rufton is offline   Reply With Quote
Old 04-19-2013, 02:00 PM   #7
meter swinger
meter swinger's Avatar
Wheel puller & spring plate compressor. Any parts store should have them. Once the wheel and spring plate are off there is a bolt to remove that holds the key tumblr in. Remove that and the tumblr will slide out.
meter swinger is offline   Reply With Quote
Old 04-19-2013, 02:02 PM   #8
meter swinger
Btw you can get door locks to match from places loke classic parts. Then you only need one key.
Old 04-19-2013, 05:09 PM   #9
Low87
Low87's Avatar
Only real trucks have two keys, why do away with that?
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 04-19-2013, 10:45 PM   #10
meter swinger
brother I got 7 rigs, thats a lot of keys to keep up with. Last one I lost was the locking gas cap on my 55 D@DG€..... PITA.
Old 04-19-2013, 11:47 PM   #11
Space Monkey
I have the same problem.
You guys are talking about a "wheel puller"? So I don't need to remove the bolts that hold on the wheel, I just need a "wheel puller"? Because I can't find a bit that fits the wheel bolts.
1982 GMC C1500 4x4 w/ 305 and sm465.
2002 Kawasaki Ninja 250.
2007 Dodge Nitro.
Space Monkey is offline   Reply With Quote
Old 04-20-2013, 12:36 AM   #12
mtnsackett
mtnsackett's Avatar
you can fix the issue one of two ways you can get an after market lock cylinder form a catalog or your local parts store I think they were selling them for about $20 or if you care and want to keep the truck with the original keys you can take the lock cylinder down to a local lock smith with your ignition key and they can put new guts in it and even cut you a new Key that doesn't have as many miles on it, I did and it was about $30 and I ended up with two new keys.
"Not all those who wander are lost." A.R.R. Tolkien... Some of us are exploring to see what is out there in this world!
mtnsackett is offline   Reply With Quote
