04-19-2013, 10:34 AM | #1 |
determining my current rear spring height
Like the title says, I purchased drop springs a few years ago and believe them to be a 4 inch drop, that is what I remember. I have added 1.5 inches worth of blocks and now think I want to lower it one more inch. I would like to confirm what I have before I purchase the 5 inch drop ones.
I will also do a little looking thru my receipts but this has been a multi year evolving project and I have a stack of receipts a trained dog cant jump over... I will measure my current ones bud didnt know if anybody has a quick reference on what the various heights are. Thanks David
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
04-22-2013, 10:08 PM | #2 |
67-72 parts collector,…
Re: determining my current rear spring height
Different brands are different heights due to spring rates and wire diameter.
04-23-2013, 04:59 AM | #3 |
Some place but not sure where is a ground to top of wheel arch factory specs. Maybe someone has that number you can use as reference keeping in mind factory size tires will give you something to go by. For some reason I'm thinking it was about 31/32"..
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
04-23-2013, 10:04 AM | #4 |
Thanks guys, I am pretty sure at the time I didnt want to go too low so I went with 4 inch but since then I have added a spacer and moved the front trailing arm mount so who knows where it is now...
here is a picture I am thinking another inch in the back? Thoughts?
04-23-2013, 10:06 AM | #5 |
I also have room to go a little lower in the front. Right now I am about an inch different on wheel opening measurement. I believe my rear is 29.5 or so but I know my tire is 28.5 so from the picture it looks like I am higher than that. I will remeasure.
08-17-2013, 02:18 PM | #6 |
Nice looking truck, I'm trying to decipher the same thing. Only I dont have any background on the truck, bought it this way. I suppose the easy way out would be airbags, not sure if I want to go that route though. I kinda like the stance of yours as it is...
08-18-2013, 02:43 PM | #7 |
I would leave it the way it is that is a nice stance IMO
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
08-18-2013, 08:38 PM | #8 |
Thanks guys I just couldn't leave it alone. I dropped it just a touch more I will post new pics.
08-19-2013, 03:31 PM | #9 |
Here it is now with a little tweeking done on the heights.
08-19-2013, 08:05 PM | #10 |
I like how it looks, nice job...Jim
my build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=459839 Jimbo's long bed step build:http://67-72chevytrucks.com/vboard/s...t=464626<br /> |
08-19-2013, 11:18 PM | #11 |
It's amazing just when you think it looks good, how much better a "little tweaking" can do. Looks good!
08-20-2013, 09:02 AM | #12 |
Thanks guys I appreciate that.
