Old 04-22-2013, 11:28 PM   #1
Truck Guy99
CD stuck in stereo! Fixable?
My bro just got a 2005 chevy silverado half ton. Factory EVERYTHING. Put a cd in, listened to it a while, and had a good time. Hit the eject button. CLICK CLICK CLICK! Then the stereo screen said "check disc". Tired of listening to the same thing. The disc is brand new and doesn't skip or anything like that. Is a new stereo in order here? If not, what is needed to fix it? Any help or pictures are appreciated greatly!
My names Tye. No Chevy right now
Truck Guy99 is offline   Reply With Quote
Old 04-22-2013, 11:38 PM   #2
SLOW POKE
SLOW POKE's Avatar
Re: CD stuck in stereo! Fixable?
My 03 does the same thing but it has a 6 disk changer... been that way for 2 years. I would also like to know if there is a solution for this.
68 Short step!!
SLOW POKE is offline   Reply With Quote
Old 04-22-2013, 11:41 PM   #3
wildfifty2
I had a CD player once that did the same thing... Until i disconected and reconected the battery supply and then it spit it right out.. Just like a computer... try rebooting it
wildfifty2 is offline   Reply With Quote
Old 04-23-2013, 09:56 AM   #4
Indian113
Indian113's Avatar
I had a CD stuck in my DD and I took it to a High End Stereo Store and they removed my Radio and removed the CD. Cost me $50.00 but was worth every penny, daughter had borrowed my truck and put a homemade RAP Cd in it.
Indian113 is offline   Reply With Quote
Old 04-23-2013, 10:05 AM   #5
Truck Guy99
I will try the battery thing. Should I do it with the ignition on, the engine running, or everything shut off? If that doesn't fix it, is there anything else I could try? If the stereo needs replacement, how hard is it to install a pioneer?
Old 04-23-2013, 10:58 AM   #6
thomas_a_reed
thomas_a_reed's Avatar
I've had this happen in several diffrent car and trucks. I use one of the reward cards like Zone gives you to get them out.. Just slide it under the lip of the disk and push eject.. works everytime atleast on single disk players.
66 CHEVY STEPSIDE 2WD W/283 ( FAMILY HAND ME DOWN)
81 CHEVY SHORT BED 2WD W/250 4SPD TRANS STRAIGHT 6 ( CURRENTLY UNDER CONSTRUCTION)
01 SILVERADO SHORT BED 2WD W/4.3 5SPD TRANS ( DAILY DRIVER) Sold
03 SIERRA 4X4 STEP SIDE EXTRA CAB 5.3 AUTO( NEW DD)
09 CHEVY COBALT W2.2 AUTO (GF'S DAILY DRIVER)
thomas_a_reed is offline   Reply With Quote
Old 04-23-2013, 11:14 AM   #7
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
I know most aftermarket stereos have a manual eject button somewhere behind the faceplate, not sure if stock ones do or not though. The last one I got a disk out of, the button was just a little pinhole. I stuck a paperclip in it, and out popped the disk. Didn't have any problems after that.
Hope that helps! Good Luck!
Jason
1960 GMC 4x4 Babe (the Blue Ox) - Build Thread
chevy_man5 is offline   Reply With Quote
Old 04-25-2013, 05:43 PM   #8
Truck Guy99
Any others? I am about to try the battery cable thing, but any extra help is greatly appreciated.
Old 04-25-2013, 06:29 PM   #9
OC 72
OC 72's Avatar
There used to be a pin hole around the unit that allowed you to eject stuck discs...look around for it...maybe it has one.
OC 72 is offline   Reply With Quote
Old 04-26-2013, 05:54 PM   #10
Truck Guy99
I tried the batterry cable thing. Didn't work. How long was I supposed to leave the cables off?
Old 07-31-2013, 05:17 AM   #11
solidaxel
solidaxel's Avatar
Is it working ???
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 08-01-2013, 01:36 AM   #12
Truck Guy99
Nope
Old 08-01-2013, 08:55 AM   #13
solidaxel
solidaxel's Avatar
Do you need to remove the surround from the dash to find the pin hole on a 2003 GMC?
LS 3 4L70E
Old 08-01-2013, 11:11 AM   #14
Truck Guy99
I couldn't find the hole.
Old 08-02-2013, 12:19 AM   #15
MadManAndrew
Did you try what Chevy Man suggested with a credit card? I've had success with that before.
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 08-02-2013, 09:36 AM   #16
chevy_man5
GMC's n H.D.'s too!
chevy_man5's Avatar
http://www.ls2.com/forums/showthread.php?t=175670
Couple of new things to try here! Good luck!!
Jason
Old 08-11-2013, 05:31 PM   #17
solidaxel
solidaxel's Avatar
When removing the battery cable will all the pre-sets be erased?
How long do you leave the battery cable disconnected?
I tried all the other options
LS 3 4L70E
Old 08-11-2013, 11:01 PM   #18
LEEVON
LEEVON's Avatar
I've got one out of my '06 that I'll sell very reasonable. PM me if interested.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 08-22-2013, 05:31 AM   #19
fluffyfreak
Are you talking about the battery supply from the vehicle to the radio? My 03 hummer does this too
fluffyfreak is offline   Reply With Quote
Old 08-22-2013, 11:07 PM   #20
motornut
78K & 79C Jimmys
motornut's Avatar
wifes got a CD player in her 05 malibu,jammed couldn't even play the radio
dinner knives,needlenose ,tweezers tried everything
.....coat hanger wire,bout 8 inches,one end put a 90 degress bend ,cut down to a little hook nib
got the center of the disc,pulled it out,does it still play CDs? no but it does play the radio and all the computer controls built in, are ok
watch disconnecting the battery,some have anti theft stuff kick in too
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 08-24-2013, 08:23 AM   #21
1slo_camaro
pull the radio out of the dash and remove the housing around everything and then you can just pull the cd right out, ive had to do this on a few factory radio and aftermarket radios
1978 2wd Fleetside, 350/th350 headers and 10 series mufflers
1998 Jeep ZJ 4.5 lift 32s full bolt ons awaiting axles
"Life is full of decisions, we make them and dont look back"
1slo_camaro is offline   Reply With Quote
Old 08-24-2013, 04:40 PM   #22
bwood
bwood's Avatar
This happened on my stepdad's 04. With something like a credit card, fold the felt back and look inside there are two little flat tabs that are suppose to drop when ejecting, his were not. I did the cc trick and got it out.
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
