Old 04-26-2013, 12:50 AM   #1
70blackfish
6 cylinder to 350 /700r4 will drive shaft fit?
my truck had a six with 3 speed manual trans, moving the 350 forward to the factory spot, with 700r4 trans...will my driveshaft fit?
I read somewhere it will work....
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 04-26-2013, 07:39 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: 6 cylinder to 350 /700r4 will drive shaft fit?
Yes, as long as you use the small block engine stands in the front holes.
Old 04-26-2013, 09:40 AM   #3
70blackfish
thats what im going to use....
thank you
Old 05-03-2013, 02:47 AM   #4
70blackfish
well my driveshaft did fit but, was 1.25 inches to short, not sure why.... oh well whats another 200.00.....
Old 05-03-2013, 07:31 AM   #5
Tx Firefighter
You used a small block engine, 700r4, and the front set of holes with small block stands ? The stands are bolted down with the factory holes and all three bolts each ?
I've done this exact swap an the driveshaft worked as is.
Old 05-03-2013, 08:59 AM   #6
Pick
Pick's Avatar
Aren't there a couple of different factory three-speed transmissions? I know mine has a non-syncronized 1st gear and I thought I read where it was shorter than the other available three-speeds? (I don't have the numbers handy at the moment......hopefully someone else might?)
1968 SWB Stepside "Bella coming home" "Bella's Build Thread"
A master in the art of living draws no sharp distinction between his work and his play. He simply pursues his vision of excellence through whatever he is doing, and leaves others to determine whether he is working or playing. To himself, he always appears to be doing both. L. P. Jack
Pick is offline   Reply With Quote
