Old 04-29-2013, 06:05 PM   #1
Patina'd_402
Patina'd_402's Avatar
Cool "California Rust"... My '70/C10/402/TH400 project...
Picked up a truck from my buddy.
It's a 1970 C-10/longbed/402/700R4.
This is how she sat, for the last 9 years.
On some 1995 Silverado wheels...
Body is pretty straight....
Except the grill/missing bumper/and driver fender.
I have replacements sourced, already.
A very clean place to start.
This is the look I'm going for in the end.
I photo-chopped it.
I should also mention that I just parted out my '88 K5 Blazer Crawler,
In order to help fund this build.
So, I'm pretty well versed in trucks/fabrication/rebuilds/etc.
My family has Chevrolet running through our veins.
I rebuild Transmissions for a living, and can fix ANYTHING with gears.
Although...
Aside from my Mom owning a '69/C10/360/TH400, this is my first experience w/ 2nd gens.
Patina'd_402 is offline   Reply With Quote
Old 04-29-2013, 06:14 PM   #2
Patina'd_402
Re: "California Rust"... My '70/C10/402/TH400 project...
And.....
The plans are:
- Go through the 402, verify everything I've been told.
* If the current setup displeases me, I'll be running a Thumper Cam, and goin' from there.
- All MSD Ign. components.
- Mate the 402 to my newly rebuilt TH400. (Mod'd for 1-2-D, EVERY upgrade possible.)
Rebuilt by me....
- Install an ECE 4/6 drop.
- All new (Poly) body/trans/motor mount bushings.
- DIY4X Poly motor mounts.
- Moog Balljoints.
- New bumpers/lights/marker lenses/etc.
The front is already disked.
I'm gonna disk the rear too.
My K5 was 3/4 Ton swapped, with disks all around.
I like full disk.
Old 04-29-2013, 07:40 PM   #3
Patina'd_402
TH400:
bought it...
Drained it...
Valve body looked new...
Ati valve plate...
Hub sockets can be slide hammers, too...
Gutted...
Tanked...
Wet...
Cured and Cleared...
Ready to go back together...
HD-TH400, HD-Clutch drums, Beefy Borg Warner clutches, HD-Sprags, beefy bearings, and a shift kit...
In all it's GLORY....
Old 04-29-2013, 08:03 PM   #4
Patina'd_402
The Solid Plan:
ignition: All MSD.
Motor: 396 BBC, .030" over, unknown internals. Gonna rebuild it.
Exhaust: JBA Shorty headers, True duals, H-pipe, No Cats, Flowmaster Super 40's.
Trans.: TH400 w/ all possible upgrades, and a 1-2-D shift kit.
Suspension/Chassis: E.C.E. 4/6 drop kit, All Poly bushings, DIY4X motor mounts.
Axle: 5-lug swapped 12b.
Brakes: will be All-Disk.
And, a few little touches here and there...
'70/C10/402/TH400.
Old 08-20-2013, 12:13 AM   #5
Patina'd_402
Close to starting....
'70/C10/402/TH400.
Old 08-20-2013, 12:32 AM   #6
Patina'd_402
Couple more.... Might piss off the purists....
Lipstick on a pig...
'70/C10/402/TH400.
Old 08-20-2013, 12:36 AM   #7
Patina'd_402
Needs more low...
Like this...
'70/C10/402/TH400.
Old 08-20-2013, 08:49 AM   #8
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
That photo shop looks killer. Someone needs to step up and make the 20" truck rallys.
--Josh
Old 08-20-2013, 08:11 PM   #9
Patina'd_402
Thanks, and yea...
The fact that I'll be saving about $3k in body/paint work (because I'm not doing it),
Will make it so I can order some custom 20" Rally's....
I'll be on em, after the bags go in.
Haters are gonna hate.
'70/C10/402/TH400.
Old 08-22-2013, 10:02 PM   #10
Patina'd_402
Radiator from a 1-Ton, Diesel.
'70/C10/402/TH400.
Old 08-22-2013, 10:20 PM   #11
Patina'd_402
My Homemade smoker (UDS), matches my engine.
'70/C10/402/TH400.
Old 08-31-2013, 04:20 PM   #12
Patina'd_402
Opinion time!!!!
Almost done CLR'ing with a Scotch Brite.
Flat, satin, or Gloss clear coat?
This is what it looks like wet....
And, a 'Chop of it dropped.
'70/C10/402/TH400.
Old 09-01-2013, 09:00 AM   #13
STOCKISH
STOCKISH's Avatar
Love it. I dont know which way you should go with the clear but it sure looks good wet. Maybe a satin clear, kinda in the middle? If it were me I would have a very hard time making that decision! lol
--Josh
Old 09-01-2013, 09:05 AM   #14
Patina'd_402
If I wasn't so lazy, I'd love to have a super wet looking clear;
But, I think the old paint might argue with the new "wet" clear, and cause lifting And other unsightly blemeshes...
Satin would look DOPE... I was thinking Flat clear, but satin is just, so, awesome.
'70/C10/402/TH400.
Old 09-01-2013, 02:16 PM   #15
Patina'd_402
I'm as far as I care to go....
The tailgate turned out AWESOME!!!
'70/C10/402/TH400.
Old 04-14-2014, 12:02 PM   #16
Patina'd_402
So...yea....
The truck is 2/4 dropped, Jeep springs out back.
Custom one piece driveshaft is in.
Ran a new wiring harness.
Installed a HUGE 4-core Radiator, made a custom shroud, and added a Volvo-850 elec. fan.
Upgraded to a CS-144 (124a) Alternator.
Fixed a bunch of little things.
Waxed the whole truck w/Mcguiers Tech Wax 2.0.
Still have a couple things to do, but I'll be on the road very soon.
'70/C10/402/TH400.
