Old 06-23-2003, 06:00 PM   #1
PrimeredThunder
Back from the Dead
PrimeredThunder's Avatar
Front Steering/Bumpstop removal?
I'm in the process of putting bags on my 72' and I have the front A-arms off and I need to remove the Bump/Steering stops off them. Whats the easiest way to go about this? Also how much drop can I expect from bags without drop spindles or a notch as say compared to stock ride height?
Thanks,
Kenny
The only Carb that matters to me is the one under my hood!
Salem, Oregon
PrimeredThunder is offline   Reply With Quote
Old 06-24-2003, 11:41 AM   #2
lost wages
lost wages's Avatar
to remove the bump stops just drill or grind on the rivets and smack them with a bfh, they will fly off, as far as drop goes, i think with the bags inflated it will be about 3 inches lower, about 6-7 inches lower with the bags empty.
lost wages is offline   Reply With Quote
Old 06-24-2003, 12:33 PM   #3
Slammed67
Progress = 0%
Slammed67's Avatar
Hmmm.... mine were spot welded on. Just drill out the spot welds, but not all the way through. Then pop them off with a hammer.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 06-24-2003, 07:21 PM   #4
PrimeredThunder
Back from the Dead
How many spot welds are there? Theres a ton of crap built up on my a-arms, was having trouble finding them all lol. I took grinder to the ones I found and slapped it around with a bfh and it wasn't moving. I'll have to try and beat on them again tonite.
Thanks,
Kenny
Salem, Oregon
Old 06-24-2003, 08:23 PM   #5
crazy longhorn
Fabricate till you "puke"
I cut mine off with a torch(the spot welded part is still on the a arm). I left the portion for the steer stop, & reinforced it on the back side with some flat strap......the steer stop does bottom on the crossmember from time to time over potholes tho.... crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 06-25-2003, 02:20 AM   #6
lost wages
lost wages's Avatar
slammed your right, now that i think of it they are just spot welded on, its been awhile since i messed with them.
Old 06-25-2003, 03:42 AM   #7
PrimeredThunder
Back from the Dead
I messed with them tonite and still couldn't get them off. Tomorrow I'm taking them to the shop and I'm going to have a friend torch them off and make the hard work easy
Kenny
Salem, Oregon
