05-06-2013, 02:46 PM | #1 |
A/C Kit Vintage vs. Old Air vs. Classic Air
So my LQ4 install is almost complete. I have a factory a/c cab and factory a/c controls and I need a complete system for my 72.
So who do you recommend there are a few companies out there. My controls are in good shape but other than that I need a whole system. Which is the best bang for the buck it seams like $1400-1500 is the most likely cost. My questions are quality, durabilty, fit & finish what do you all recommend. Thanks! |
05-06-2013, 03:25 PM | #2 |
Re: A/C Kit Vintage vs. Old Air vs. Classic Air
There are a TON of threads that outline just about every positive and negative point of each system on this forum. If you use the search tool on top and select 67-72chevytrucks you will find the answer you seek! Good Luck!
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
05-06-2013, 05:06 PM | #3 |
Subscribed ..the search tool is great, use it all the time, but us newbies what to hear the latest
1970 C10 Short Stepper with 71/72 front clip. |
05-06-2013, 05:44 PM | #4 |
I researched them all and vintage air is the only one that I could find that lets you use your factory controls this may not be a big deal to most but I just like the factory stock look. I went with vjntage air because basically it is exactly the same price as old air. there is a board member Scottshotrods that you can get a very good deal from.
Posted via Mobile Device |
05-06-2013, 09:15 PM | #5 |
As the proud owner of an Old Air Hurricane system... I would highly recommend Vintage.
05-06-2013, 09:19 PM | #6 | |
05-06-2013, 09:24 PM | #7 | |
Old member
I used Classic auto air http://www.classicautoair.com/67_72_..._Chevy_AC.html
05-06-2013, 09:55 PM | #8 |
Use your lq4 compressor - get Vintage inside unit, condensor and drier combo, and the right fittings with hoses -- around $1000 that's what I did and I am very pleased
High School Project I ---http://67-72chevytrucks.com/vboard/s...d.php?t=639174 High School Project II ---http://67-72chevytrucks.com/vboard/s...27#post7290427 High School Project III ---http://67-72chevytrucks.com/vboard/s...d.php?t=715832 High School Project IV (Tyler) ---http://67-72chevytrucks.com/vboard/s...d.php?t=780186 |
05-06-2013, 10:34 PM | #9 |
I used classic auto air and use my factory AC controls. The levers don't operate exactly the same as stock but it works great.
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped 1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant |
05-06-2013, 11:06 PM | #10 |
motor exploder
Call Justin @ Scott's Hot Rods and order up a Vintage Air kit - you'll be doing yourself a favor and saving a lot of time. He was easy to deal with, knows our trucks well and will get you a killer deal on everything you need. I got my Vintage Air kit from him, so I'm speaking from experience.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
05-06-2013, 11:46 PM | #11 |
I would use Vintage Air. And I would stay FAR AWAY from Hot Rod Air(if they're still in business).
05-07-2013, 12:31 AM | #12 |
Love my vintage air system. Have been driving around in upper 80s last couple days and it has been oh so cool inside the cab. Vintage air gets it done!
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130 Club longbed ...cause girls like'em long!!!!! |
05-07-2013, 08:59 PM | #13 |
Thanks for the responses. I only have the controls. The compressor was damaged on the LQ4. It was pulled from a wrecked van.
I guess Vintage Air it is. I'll be ready to order in one week. Posted via Mobile Device |
05-07-2013, 09:41 PM | #14 |
Old member
If u want really good cold air do the cab mod on the cowl vent also. Close the cowl vent up completely. Seal it off so no ouside air can get into cab. Then once the system is operating open the passenger side vent to recirculate the cab air. Mine runs 38 degree's now all the time.
