Old 05-07-2013, 07:51 AM   #1
BigDaddyV
BigDaddyV's Avatar
drop block hole width and dia.
Sup guys. Im gonna try to make some drop blocks for my 72 coil spring rear end. Can anyone measure the width between the U-bolts and the dia. of eeach side for me. I'm at work and don't have the truck with me.
Thank you for youor help.
J. Vess, 6'6", Gearhead, Welder, Fabricator, Nutcase
1955 Chevy Stepside "Dudley"
My daily http://www.67-72chevytrucks.com/vboa...d.php?t=760288
1972 Chevy C10, Project "Chevro~Layed out" Nether Storm
Build Thread http://67-72chevytrucks.com/vboard/s...23#post6007523
BigDaddyV is offline   Reply With Quote
Old 05-07-2013, 12:27 PM   #2
69gmcc10
69gmcc10's Avatar
Re: drop block hole width and dia.
I used a 7/8" drill to make the holes for the block so there was a little bit of wiggle room for alignment, but I also used 3/4" rod for the u-bolt (some people use a smaller rod, I advise 3/4"). There should be 3 1/2" of gap between the sides of the u bolt and you want the bolt just to slide right in so you need the center of the holes to be 4 3/8" apart.
3 1/2" + (.5 x 7/8"= hole center x 2)= 4 3/8"
I also explain it on my build thread if you want to take a look!
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 05-07-2013, 01:11 PM   #3
BigDaddyV
BigDaddyV's Avatar
Thank you bud! you are the man!
Old 05-07-2013, 10:16 PM   #4
Square_78
Square_78's Avatar
Holes should be 4.25" on center. I also drilled 7/8" holes in mine to allow ease of installation.
#teamlongbed
"I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb
1978 Chevy shop truck - static 6/8"
1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497
Square_78 is offline   Reply With Quote
Old 05-08-2013, 06:21 AM   #5
BigDaddyV
BigDaddyV's Avatar
I made some yesterday with yalls specs. perfect fit. Now I just need to get some longer u bolts. I talked to bud that is gonna hook me up.
