Old 05-07-2013, 09:54 PM   #1
tdj4bama
tdj4bama's Avatar
3 OTT steering column help
I have a 68 that has a three speed column shift. My problem is, when I shift gears the piece between the steering wheel and the shifter sleeve (that houses the turn signal/ hazard light/ cancelling cam etc) rotates with the shifter sleeve. Its not a lot but enough that it wears the wires inside and then crazy things happen (my horn blows when i shift gears or turn signals come on) not sure if I'm missing something or if a part is broken. Any help would be greatly appreciated.
Thanks,
Truman
tdj4bama is offline   Reply With Quote
