1996-2000 Vortec Engine Swap (Help)
I was wondering if anyone knew of any sites that covered a 4.9 L or 5.3 L Vortec engine swap into a 1972 C10. I will either be getting a motor and tranny from a Caprice (cop car) or a truck. I'm sure others have done this but before I get started I want to see what I'm in for. I have looked for a while now and just can't find much. I would appriciate any responses. Thank-you.
Workin to live...
4.8L or 5.3L are only in the trucks, and from model years 1999 and up!!
Jason 1996 Viper GTS - Blue/White 2015 ¾ton Ram Cummins - White 2012 BMW X5 35d TT Diesel - Grey 2007 5.7L Dodge Charger Police Package - White SOLD!! 1972 GMC Jimmy 350/350/205 - Hugger Orange SOLD!!1972 Chevy Blazer 350HO/350/205 - Hugger Orange |
Workin to live...
Sorry, either the 5.7 from a 1991 - 1996 Caprice or 5.3 from a new truck. Thank-you Jason. I should have been more specific.
Spank 'em if you got 'em!
That's neat! If you use the cop car engine are you going to put the "Interceptor" badge on the back?
Long Knight '71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick |
Id probably get pulled over for that. But its a thought.
The cheapest/easiest swap would be a 96-98 in trucks Vortec 5.7 or up until 2000 in vans, it is basicall a first gen small block. If you want to go to a 5.3/6.0 street & performance sells motormounts for some applications.
44 Willys MB 52 M38A1 64 Corvette Coupe 68 Camaro 'vert LT1 & TH700 69 Z/28 355 12.6's @110 72 Jimmy 4WD 4spd 4" & 35's 72 240Z-2.9l L6, triple Del'Lortos, T5, 12mm R200 LSD 85 FJ1100 & 01 XR400 86 Kawasaki X2 & 89 SX650 w/PJS cylinder and dual carbs 02 GMC 2500HD 4x4 Duramax |
Nitrous Freak
![]() Join Date: Dec 2002
Do those 96-98 truck Vortecs have a mechanical fuel pump boss or is it electric pump only? I am assuming it doesnt have the boss so you are going to have to run an electric pump and all that jazz with it...Right?
thanks CHRIS
68 C10 shortbed -- Street/Strip ![]() |
It uses a high pressure fuel pump as far as I know. It is in the gas tank so I would run an inline.
I was definitally thinking about getting a 5.7 out of a van but I have a lead on a 2000 truck that is totalled. Thank you for the replies. |
Here's a pick of my '97 truck engine. I converted to carb and while there is a boss for the pump, it isn't usable, it's blocked off. Stock, they use a high pressure in-tank pump. I'm running an electric pump myself for the carb. The wiring harness and pcm (you need a '96 pcm) made the cost to convert too high for the return. Maybe some day I'll go fuel injected, but it will be some aftermarket or TPI. You know looks and all the benefits. I' run the exact serpentine setup that came on the truck. Don't have the a/c plumbed yet though. The fan shroud is a BB shroud for our model with the '97 stock fan blade. Fit is perfect.
http://home.comcast.net/~r.landrum/w...tos.html-.html '68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades. |
Windy Corner of a Dirty Street
Late model serpentine belt systems are cool! My 78’ K10 with a crate 454 HO is set up like a L29 BB 454 from a 2000 model year old style 2500 series truck. Will be adding sequential fuel injection later this summer once I score a GM marine controller.
Current vehicle collection: 1968 GMC C1500, 396, TH400 1978 Chevrolet K10, 8.1L, NV4500, NP205 1989 Chevrolet Suburban, 8.1L, NV4500, NP241 1993 Chevrolet C1500 Sportside, TBI 7.4L, 4L60E 2001 Chevrolet K2500HD, Ext Cab, SWB, 8.1L, ZF 6 speed 2014 Chevrolet Impala LTZ 3.6L Vortec 8.1L because life is too short to tolerate underpowered vehicles
Thread Tools | |
Display Modes | |
