Old 06-24-2003, 03:45 PM   #1
biddaboy
biddaboy's Avatar
Housing picture for ID
Forgot the pic of the housing for ID stamp # HC 12 10 W with letter E below stamp # Thanks biddaboy
biddaboy is offline   Reply With Quote
Old 06-24-2003, 03:54 PM   #2
Long Knight
Spank 'em if you got 'em!
Long Knight's Avatar
Cool stand!
Long Knight
'71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick
Long Knight is offline   Reply With Quote
Old 06-25-2003, 12:11 AM   #3
Mike C
Mike C's Avatar
Hard to say from that angle, either a 12 bolt, Dana 44, or a Dana 60. If it is 5 or 6 lug it is most likely a 12 bolt. There were some Dana 44 in the rear of 67-68 GMC, but I have never seen a coil spring 44. If it is 8 lug it is a 60. In 67-68 there were some big block trucks that had a 6 lug Dana 60, but are uncommon. If you have a pic of the other side, it will be easier. But regardless, it is not an Eaton!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-25-2003, 07:30 AM   #4
JJR
JJR's Avatar
Hollanders shows code HA as a 3.73 12 bolt that could have come in a 65-69 C-10. The 65 model was a posi and the 66-69 was not. Hope this helps.
FOUNDING MEMBER OF THE DRUM BRAKE CLUB
Second Owner 70 C-10
Second Owner 93 GMC C1500
Third Owner 99 C2500 Crew Cab Short Bed
JJR is offline   Reply With Quote
