Old 05-13-2013, 10:40 PM   #1
sportfish69
1969 Gmc vs Chevy fender
I have a 1969 GMC stepside. Is there a difference between the fenders and hood or are they interchangeable?
sportfish69 is offline   Reply With Quote
Old 05-13-2013, 11:32 PM   #2
Shyguy
Junior Member
Shyguy's Avatar
Re: 1969 Gmc vs Chevy fender
GMC fenders only work on GMC and 67-68 Chevys. Of course 67 chevys do not have the side marker lights.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 05-13-2013, 11:52 PM   #3
Hardesty454
Hardesty454's Avatar
What he said...
Ive been searching for those darn GMC or 67-68 chevy fenders for a while now to help on my clip swap. Wana swap!?
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 05-14-2013, 10:07 AM   #4
71gmcburb
71gmcburb's Avatar
The difference in the fenders is that 69-72 Chevy fenders don't have holes for the trim next to the grill on the leading edge of the fender. Other then that they are the same. The hoods are different the same way. GMC has a trim along the leading edge. If you are good at welding you can plug the holes and have Chevy fenders and hood. The core support is not interchangable
a wise man once said "There are only two real rules to life...
1 - Don't sweat the small stuff
2 - Everything is small stuff
71gmcburb is offline   Reply With Quote
Old 05-14-2013, 12:49 PM   #5
sportfish69
I like the grill and double headlights on the GMC.
My drivers side fender has a dent on the front and rust on the bottom. I was going to look for a fender that is not damaged to replace it but having a hard time locating one for a GMC. Sounds like the Chevy and GMC fenders are the same except for bolt holes for the trim around the grill if I understand you correctly.
Old 05-14-2013, 01:32 PM   #6
67c10rustbuket
67c10rustbuket's Avatar
The leading edge of the fenders is different. The '69+ CHEVY have a ridge where the grill mounts to. See the difference in this pic.
White fender is a 1969-1972 CHEVY
Blue fender is a 1968 CHEVY or 1968-1972 GMC
Pic borrowed from this site of course
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
