06-24-2003, 09:24 PM | #1 |
HEI in 4x4 ??
Hey guy's you all have been great helping
with part leads, this newbe is greatfull. Now for my next question, is it possable to slide a HEI dizy in to the 4x4's ? Looking at the 2X trucks it looks like a slam dunk, but in my 4x4 it looks like it would be real tight if at all possable. I assume someone on thee list has done the field work already. Mike D.
72 3/4 ton 4X4 Suburban (and way to many FSJ's (J series jeeps) |
06-24-2003, 09:28 PM | #2 |
Recovering 67-72 Addict
No problem, it will go right in (with the cap off of course).
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
06-24-2003, 09:29 PM | #3 |
it will fight, a smaller aftermarket HEI would be a breeze.
06-24-2003, 09:30 PM | #4 |
Sweet ! (Next time I am under the hood HEI time !)
Mike D.
06-24-2003, 09:38 PM | #5 |
Are there smaller HEI (non computer controlled)
avalible ? Mike D.
06-25-2003, 12:00 AM | #6 |
Roadtrip!
HEI
A stock hei will fit, but it is tight! On my 70 4x4 i have to take cap off to get it in or out, and back plug wire is tight against the fire wall (big block) Aftermarket (unilite, mallory) would be better if you want to spend the $. I am about 3 hours north of you if you need any parts, maybe i can help. Eric
06-25-2003, 12:02 AM | #7 |
I elected to run the MSD ready-to-run distributor in my JImmy and have been pleased as punch. It uses the small window cap.
