Old 05-15-2013, 11:11 PM   #1
aggie91
I'm just glad to be here!
aggie91's Avatar
Exclamation 4L60e help !!!!
I have a trans I got on trade and looks to have been rebuilt recently. The tag on top was painted over. The only codes I have are the one engraved on the pan rail next to the tail shaft housing.
The numbers are:
0CAD055E 27086769
My question is: Will it work behind a 2000 LM7 LS 5.3 Vortec engine with a stock reprogrammed PCM.
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 05-16-2013, 07:21 AM   #2
Bigdav160
Bigdav160's Avatar
Re: 4L60e help !!!!
0CAD is probably from a 2000 pickup. Should work
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 05-16-2013, 04:35 PM   #3
aggie91
aggie91's Avatar
Re: 4L60e help !!!!
Thanks. After I posted the question I found online it is a 2000 model, but the CA means it was behind a 4.3 V6 engine. Given that, I am not sure it will work with a LS and a stock reflashed PCM.
Karl
The LST Challenge:
Old 05-19-2013, 08:09 PM   #4
clinebarger
Re: 4L60e help !!!!
Remove the torque converter & take a pic of the input shaft.....
clinebarger is offline   Reply With Quote
Old 05-20-2013, 08:27 AM   #5
smoky02
Location: Sunny, Florida, some might call it South Alabama
Re: 4L60e help !!!!
The v6 trannies came with a smaller input shaft and less clutches. It will need to be upgraded
Just sold my C10...sad day...
Looking for a 1972 Blazer to hopefully fill the hole in my heart.
smoky02 is offline   Reply With Quote
Old 05-20-2013, 08:30 PM   #6
clinebarger
Re: 4L60e help !!!!
4.3L & V8 4L60E's all have the same number of clutches. "245mm" 4L60E's did use fewer clutches. (i.e. 2.2L, 2.5L, 3.4L & 3.8L used in S-10 & 4th gen F-bodies)
'93-'02 4.3L, 5.0L, & 5.7L use a "295mm" 4L60E.
98-present Gen III engines use a "300mm" 4L60E.
'03 & up 4.3L's use a 295mm/300mm hybrid of sorts & have not really checked them out....But they are different.
4l60e, trans swap
