Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-17-2013, 09:18 AM   #1
funnyfarmracer
I'm sure this has been covered but....
Best springs for bbc powered LWB 69 chevy??? Is pinion angle even an issue with these trucks??? Good cheap shocks???
Starting a new project.
69 lwb 1/2 ton
ho 72 rear diff with 4.57 gears
468 BBc oval ports, mild flat tappet cam, forged pistons and lots of nitrous.
two plates a cheater and a big shot
th350 3200 stall
just want cheap fun as you can tell
funnyfarmracer is offline   Reply With Quote
Old 05-17-2013, 04:36 PM   #2
Blue Rat
Re: I'm sure this has been covered but....
Sounds like that is going to get to be $$$$
Blue Rat is offline   Reply With Quote
Old 05-17-2013, 06:59 PM   #3
funnyfarmracer
Not really. I already have all the parts just want to get it to hook on the cheap and be fun. I want my boys to be able to drive it too.
Old 05-18-2013, 09:39 AM   #4
Blue Rat
That is a plan!
Wish I had all my parts!
Old 05-30-2013, 06:10 PM   #5
gofastnut
gofastnut's Avatar
Are you lowering it? You might take a look at pinion angle...
Don't go too cheap on the shocks, you'll regret it. Unless you're trying to get your suspension figured out and NEED something. Then by all means, go cheap!
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 05-30-2013, 09:28 PM   #6
Super73
Super73's Avatar
There is no true answer to your question with out more info. Front and rear weights along with compressed height based on desired ride height are parts of the puzzle. That info will allow us to help give you an educated guess.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 06-25-2013, 11:55 PM   #7
low&slow
Without getting all technical on you, I assume the truck isn't lowered and the suspension parts are stock excluding the rear end. For cheap fun, I say just go buy new shocks. They will be stiffer that your old worn out ones. And get some fatter tires. Also with all the Nitrous, try leaving at a lower rpm or not use the nos right off the launch. I'd say that's about as cheap as you can go if you're just wanting some fun on the weekends. If you want to not go cheap, then listen to the guys above lol
low&slow is offline   Reply With Quote
