Old 05-17-2013, 06:52 PM   #1
dkauffman05
dkauffman05's Avatar
K10 oil pan
Putting a lq4 in soon and plan on using dirty dingo mounts in a 86 k10 . I caint find a 100% answer if the truck pan will work or not . Anyone know ?
dkauffman05 is offline   Reply With Quote
Old 05-17-2013, 07:26 PM   #2
dkauffman05
Re: K10 oil pan
They guy I'm doing it for also request that the t-case shifter stay in the stock location. So the lq4 will be located in the sbc location. Also the truck is a 86 k10. I read some people have to notch or remove the front crossmember , but I'm sure that's due to engine placement and driveline angle .
Old 05-17-2013, 09:14 PM   #3
85burb
85burb's Avatar
Re: K10 oil pan
I have a 85 k10 burb and i used dirtydingo mounts and a stock truck oil pan. I am not sure if my frame mounts are bent or what but my pan cleared the member everyware except the front threaded tab that the plastic harness deal bolts on to. But that side of the motor sits low for some reason. Off road design makes a tubular crossmember that gives extra clearance. I asked them and they said to order the big block one. The pan did not hit tell my motor mount bushings twisted with the factory member.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 05-17-2013, 10:59 PM   #4
dkauffman05
Re: K10 oil pan
I've seen the aftermarket crossmembers but I was thinking and hopeing it would work with the truck pan and stock crossmember.
Old 05-17-2013, 11:02 PM   #5
85burb
85burb's Avatar
Re: K10 oil pan
Mine did. Tell something bent. The main reason I got that is it bolts to the frame and the motor mount area together.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-18-2013, 08:06 AM   #6
ghettoluxury
ghettoluxury's Avatar
Re: K10 oil pan
It is like GM designed this engine for a 73-87, they fit that well.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
