turn over but will not start
I have an 81 c10 with a 350 and it will turn over, plus it has fuel going in, but I won't start.
Posted via Mobile Device Posted via Mobile Device |
Re: turn over but will not start
Did you check for spark? check the ignition system
F.A.S.T.
Fuel Air Spark Timing start with the basics good luck |
I think I made a mistake in the wiring of the starter. Are there any cables that go from the starter to the distributor
#5 | |
![]() Join Date: Apr 2009
Desert Last edited by Desert1957; 05-27-2013 at 11:04 AM. |
here is a pic
Thank you very much. I kept reading that there is no wire going from the starter to distributor if its HEI? Is this true?
Junior Member
If it has a Hei distributor it gets its power from the ignition switch, if I remember right. On some trucks there is a 12 volt feed from the large positive post on the battery to the fuse block, but I am not sure which years.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
78K & 79C Jimmys
the HEI wire comes out of the harness,through the firewall plug
not right from the bat(needs on/off)
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Tags |
turnover, will not start |
