Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 05-27-2013, 12:28 AM   #1
gfreeze1025
gfreeze1025's Avatar
Bedliner Options
I have searched the forums and nothing really answers the question I have.
I am in the middle of a restore on my 71 Blazer and just stripped out the carpet and padding (which was glued down = )..
I plan on dynamatting ( or some other alternative) and new carpet, but prior to that I want line the bed with "something" to help prevent rust etc. It will cover from the firewall to the tailgate. Also, I need a DIY option.
Blazer stripped out..
Name:  2013-05-26 15.01.01.jpg
The question what should I use? I looked at POR15, Herculiner, Rust-Oleum Truck Bed Coating, and just plain old primer and paint.
I don't really care about what it looks like or UV protection as I will be covering it up with carpet and dynamat. It just needs to protect/seal the cab/bed against rust. (ie rain when the top is down)
Any thoughts/ideas will be appreciated
Gary
1971 K5 Blazer 350 V8
gfreeze1025 is offline   Reply With Quote
Old 05-27-2013, 07:22 AM   #2
notsolo
notsolo's Avatar
Re: Bedliner Options
Rust should be treated before undercoating, IMO...I like this over POR15 www.masterseriescoatings.com/index/ the master coat silver fills in some small pitted areas....I also use U-POL Raptor tintable bedliner it uses urethane paint to tint, also comes in black.
notsolo is offline   Reply With Quote
Old 05-27-2013, 09:18 AM   #3
jaros44sr
jaros44sr's Avatar
X2 on the rust treatment...have you looked into lizardskin, heard good things about that product. Dusty has it on his blazer
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
